Hard to start
Old Jul 9, 2021 | 06:08 PM
Dan K's Avatar
Dan K
Here is another video of the injector operation. Sorry it goes in and out of focus. I checked the coolant temperature reading after sitting overnight and it is right on.
File Type: mov
Old Jul 9, 2021 | 06:31 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
OK, so you are getting injector pulse…I think you showed spark using an timing light…just pull the plug wire off the coil pack and keep about a 1/2 inch or so distance between them…see if the spark jumps while cranking… do a plug wire on each bank…each bank has its own ground and both banks are joined with an eye terminal behind the left cylinder head !!
Old Jul 10, 2021 | 05:05 PM
solidaxel's Avatar
solidaxel
Old Jul 10, 2021 | 07:04 PM
Dan K's Avatar
Dan K
Was getting ready to run the tests you suggested but now having another issue with the car much more serious. Need to fix it first.
Old Jul 12, 2021 | 06:46 PM
Dan K's Avatar
Dan K
Here is the test I just did for the left side coil pack. I will also attach the one I did before for the right side (it is the one that is out of focus). Both show spark during the cranking and before the engine starts. I am thinking of trying this again but pulling the fuses for the injectors before I hit the start button. When it starts crank wait a second then plug the fuses back in and see if it starts right up. I would hope this would tell me if the engine control computer is dumping in extra fuel, flooding the cylinders causing the extra crank time. Your thoughts? Thanks, Dan
File Type: mov
File Type: mov
Old Jul 12, 2021 | 09:32 PM
Dan K's Avatar
Dan K
My idea seems to not be showing what I had hopped. You can see in the video I hit the start button then single for my neighbor to push in the fuses and there seems to be no difference then when the fuses were in place to start with. What do you think? Any other ideas after seeing these tests? Thanks Dan
File Type: mov
