My 007 C6 dynoed a max of 605whp/570wtq, it makes 500wtq at 3250rpm and builds from there.
The car has 30000 miles, the 6L80e trans is stock, has been serviced twice and never overheated. I am trying to save the trans by never doing burn outs or hard launches. With that said I will make 2 maybe 3 drag strip passes with mildly heating the DRs. It should run 10.80.
I live for the roll race and will provoke a roll race at every opportunity. These contests are from as slow as 40mph up to the top of 4th gear at the most. I never shift into 5th under full power.
Do you think the trans will survive this use?
RPM Transmissions does not list a built 6L80.
Who sells a strong 6L80?
Do you run an external trans cooler? If not...get one. It will help tremendously with heat. As for the tranny holding up, there are stories of built tranny's lasting 100s of passes without issue. I have a little more power than you and my 6l80 failed miserably. As far as I know RPM trans will not touch a 6l80. Actually the options for built 6l80s is not great. Century Trans and Circle D are your best bets for a built 6l80. Be prepared to spend a small fortune. The 6l80 was just not designed to hold the power we put down on these cars. You even hear of built 6l80s failing after just a short while of beating on them.
I have hundreds of passes on mine (bone stock trans) with well over 600rwhp. The life of a 6L80 is all in the tune and managing heat, if both are those are good, it will live a long time.
I use Justin Covington at Asylum Motorsports in Baton Rouge, La for my tuning and if I ever need one built, he's doing it. I'm pretty sure he has the overall record right now with his G8. But in your area, I've heard good things about Tim King, he's in Ohio.
^^This and the post before this one. The only 6l80’s that live are tuned by someone that’s already blown up a few at a minimum. From what i’ve read they’re very sensitive to shift pressure if i remember right(could be wrong). Probably the best option is Century transmissions. RPM won’t do them because they know they still won’t hold up. Their design is not the best for high torque. They seem to do rather well under 700wheel with the right tuner. As for what you want to do i would think you will be fine. Most auto trans seem to fail when people shift into too high a gear, or from hard launches and heat build up from burnouts and then a hard 1-2 shifts. Put a cooler on it if you don’t have one and let it rip.
I've been racing my car with a 6L80 for about 2.5-3yrs now and here's what I've learned.
1. A good tune is 90% of the fight. Find somebody whose very good with trans tuning and 6L80s. That will be the biggest thing to keep it running.
2. Heat is your enemy. A good trans cooler and keeping your trans temps 185 and under will help a lot.
3. Don't ever just mash the gas in D. 6L80s will sometimes shift really weird or upshift into a bigger gear. 4-5-6 gears are much weaker than the 1-2-3. Burning up 4-5-6 is the most common way the 6l80s die. I have my car set up that when I'm sport mode i use my paddles to pick which gear i want to be in, then it shifts for me automatically from there. That way it does have to kick down when WOT. Also makes burnouts and launching easier.
4. Best way to build the 6L80 trans is to get a Sonnax rebuild kit, weld the clutch baskets and buy a billet intermediate shaft. I have been racing my car with 800ish RWHP on a completely stock 6L80e for more than 2 years. I have an after market transcooler and a Circle D 3400 billet stall as well.
What needs to be done to set the paddles up like that? I need to do that.
Tune. It's the way it's tuned. Mine does the same.. Bump down with paddles and it will upshift if I'm WOT, if not, it will hold the gear.
Gotcha, I will have my tuner look into that after I get the new transmission back. And I kinda new it was in the tune, I meant specifically what in the tune needs to be changed to do this?
I'm not real sure as I'm not a tuner. But I'm thinking the good 6L80 tuners don't share their know how..
No clue but my tuner told me about the feature after he was done.
Also keep in mind that the earlier A6 models may not have all the same tuning abilities as the later A6 models (e.g. the one in the grand sport). I think the electronic modules and programming were updated in 08 and then again when the GS was introduced.
The 6L80E when rolled out in the C7 had A LOT of problems and failures. I don't trust the 6L80E. It's nice to have the 2 extra gear ratios but not worth the headaches. The 4L80E is tried and true, especially a built one.
While a 4L80E can be made to fit in a C6, it requires a ton of work including having to cut the tunnel.
A 6L80E however is an extremely decent transmission, especially if it's rebuilt with Alto clutches and tuned properly. I can say this with absolute confidence as I've kinda become the poster child over the last several years for throwing considerable abuse at the transmission and proving what it's capable of handling.
