Wire diagram needed
Old Apr 21, 2021 | 12:48 PM
c5maniac2's Avatar
c5maniac2
Default Wire diagram needed
Can anyone post a wiring diagram for 2009 Z06 clutch pedal position sensor? Trying to see if I can tap into it under the hood.
Old Apr 21, 2021 | 04:08 PM
jft69z's Avatar
jft69z
Try this.
Look for X180 on the xxx500 document, that's the underhood connector with the wires you're looking for.
File Type: pdf
File Type: pdf
File Type: pdf
Old Apr 21, 2021 | 04:57 PM
c5maniac2's Avatar
c5maniac2
Originally Posted by jft69z
Try this.
You are the man! Thank you!
Old Apr 21, 2021 | 05:05 PM
jft69z's Avatar
jft69z
You're welcome.
Old Apr 21, 2021 | 08:22 PM
Dano523's Avatar
Dano523
FYI, but will need to do a CPS relearn, since you will be changing the ohm values of the sensor to the BCM, with it now being tapped with something else.
Also keep in mind that the Clutch sensor is working off ohm readings as the pedal changes positions, and depending on what you are tapping into it, it may need to learn these new values of the different pedal positions as well. The later vet clutch position sensors, are really just brake pedal sensor.
The 2005 vet is the one that had the on/off type switch on the bottom of the pedal, and another on the top of pedal stroke. so depending on what you are installing, may be better off just installing one of these switches to use for the after market device isntead. Hence could be used independently, and will not screw with what the BCM is seeing for ohm resistance from the later clutch pedal sensor.
To Wire diagram needed
