:fast 102
Old May 20, 2021 | 09:38 PM
joevette perdomo's Avatar
joevette perdomo
Default :fast 102
Can someone tell me when installing a fast intake on an ls2, and going with ls7 injectors and after market fuel rails will I need any adapters/spacers for the injectors or is it just for the oem fuel rails?
Old May 21, 2021 | 06:11 PM
joevette perdomo
Bump anybody
Old May 21, 2021 | 06:24 PM
BigBlok502's Avatar
BigBlok502
I installed a ported FAST 102 on my LS2 and originally ordered Holley Fuels Rails for an LS2 and found out they would not fit the FAST intake, only the stock intake. Ultimately I used the stock fuel rail with stock LS2 injectors. I don't have the answer about using LS7 injectors, but my guess is they are a different length, as are LS3 injectors, than the LS2 injectors.
Old May 21, 2021 | 06:30 PM
joevette perdomo
Hey thanks for replying, when you say they would not fit what was the problem, I have I believe fast fuel rails, and yes the ls3 /Ls7 are shorter but I was thinking height wouldn't be an issue concidering there not bridged together?
Old May 22, 2021 | 11:48 AM
BigBlok502's Avatar
BigBlok502
Originally Posted by joevette perdomo
Hey thanks for replying, when you say they would not fit what was the problem?
The brackets that came with the Holley Fuel Rails did not sit flush with the mounting holes. I could have modified them to fit, but chose to just return the fuel rails and use the OEM fuel rails instead.
Old May 22, 2021 | 03:03 PM
joevette perdomo
Understand now hope I can get the aeromotive rails to work as I had them powder coated.
Old Jun 2, 2021 | 06:19 PM
Excind's Avatar
Excind
I installed a ported FAST 102 on my LS2.
Not to hijack the thread but was the 102 plug and play or did you have to mod the firewall/use shorter engine mounts?
Old Jun 2, 2021 | 06:27 PM
BigBlok502's Avatar
BigBlok502
It was pretty much plug and play, no modifications to the firewall or shorter engine mounts.
Old Jun 3, 2021 | 01:14 PM
joevette perdomo
Update aeromotive fuel rails worked fine pictures for reference still waiting on tuner though.
Old Jun 3, 2021 | 07:42 PM
Excind's Avatar
Excind
Thanks Bigblok!
To :fast 102
