LS3 Intake Manifold.
Old Jun 20, 2021 | 07:09 PM
Wesker's Avatar
Wesker
Default LS3 Intake Manifold.
Hi guys.
I have a question n with all due respect to everyone i would appreciate if someone states facts, not opinion.
With that being said...
Will an LS3 Vette benefit from Intake Manifold?
If so, how much of a difference in HP can i expect?
Old Jun 20, 2021 | 07:16 PM
gdmoore01's Avatar
gdmoore01
Your basic question was recently answered within this thread below. My opinion was submitted within, but there are also several responses with the actual facts:
https://www.corvetteforum.com/forums...-worth-it.html
GD
Old Jun 21, 2021 | 07:50 AM
old motorhead's Avatar
old motorhead
Unlike the stock LS2 intake manifold, the stock LS3 version is quite good. Upgrading that piece to an aftermarket unit won't do much other than make your wallet thinner. If you have a heavily modded engine that spends all its time above 5000 rpm, there might be a place for an aftermarket manifold. For 98% of the street Vettes, it's a waste of time and money. Here's an intake manifold test that shows a few options and what they're capable of : The Ultimate LS3 Intake Manifold Dyno Shootout! - Gwatney Performance
You'll notice ported heads and a fairly big cam were used for the test. An engine with less mods would show less differences.
I had Gwatney port and rod mod my stock LS3 intake manifold. I think it cost $400 back when I had it done. I have no idea what they charge now. I'm pleased with it, but did no before/after testing.
Old Jun 21, 2021 | 12:05 PM
whowon's Avatar
whowon
IMO the small gain from an aftermarket manifold is from the use of a 102mm throttle body, not the manifold itself. I have a Gwatney ported manifold along with ported throttle body as well, but did no before and after testing.
Old Jun 21, 2021 | 12:12 PM
GS_DAN's Avatar
GS_DAN
If you have other mods done to your car (heads, cam, headers, etc.) I think it can benefit well. The "rod mod" and ported stock LS3 manifold seems like the best performance gain over aftermarket. I had Modern Airflow Dynamics in Houston do mine. I'd say roughly ~15whp gain.
Old Jun 24, 2021 | 11:54 AM
Wesker's Avatar
Wesker
GD
Thank u guys for the help. I have decided that i will not upgrade the Mani until i get heads, cam and TB.
Old Jun 25, 2021 | 06:46 PM
Av8TD RAcEr's Avatar
Av8TD RAcEr
Cruising
It seems many have rodded/modded intakes and ported TB’s with no before and after testing.
since I am waiting on the arrival of both TB and manifold and a cam package I will try to do testing with just install of the cam with stock manifold,TB, heads for baseline then another with the rodded manifold and TB installed.
down the track if I do heads I can easily test both again. 👍🏽
id say it would be more than likely that any gains made would be more torque related than hp with stock heads. Most people do however report a better feeling throttle pick up/response
Old Jul 30, 2021 | 10:54 PM
Turbotalon1g's Avatar
Turbotalon1g
Any updates?
I think i'm going to do it I want my powerband to be at 6500-7k max RPM, the car already has enough oiling issues as it is.
Old Aug 7, 2021 | 01:47 PM
d16dcoe45's Avatar
d16dcoe45
Originally Posted by Turbotalon1g
Any updates?
The rod modded and ported manifolds really hit a wall around 6800. If you have a decent cam and heads I would skip right over the plastic manifolds. I just sold my Rod Modded and ported Gwatney LS3 and went with a medium Sniper and I shift at 7400--I never dynoed but the car is clearly quicker than with the Rod Mod.
To LS3 Intake Manifold.
