Hiss when speakers are engaged
Old Jun 29, 2021 | 06:38 PM
wtb-z's Avatar
wtb-z
Default Hiss when speakers are engaged
Car: 2011 GS with the bose 7 speaker system (U65 RPO code), non-nav head unit
Issue:
* Whenever the speakers are engaged, the system makes a hiss that is noticeable unless the radio is playing pretty loud music over it
* Hiss is present on all audio sources, including when the car is using the speakers for the warning chime or button input beep
* Engine on can be on or off
* No hiss when the speakers are not engaged (e.g., volume=0, mute, and the car has not recently attempted a chime/beep)
* Hiss does not seem vary much radio volume setting (as long as radio is not volume=0 or muted)
* Speakers on both sides of the car seem to hiss
* Amp installation looks stock
It seems like there have been a few complaints about this over the years when I search, but no really useful results. This hiss feels quite loud to be considered "normal". I was thinking of trying out a used amp, but I hate to throw $$$ parts at a problem blindly.
Old Jun 29, 2021 | 06:57 PM
ClothSeats's Avatar
ClothSeats
I think you might get better response by posting in the Audio/Electronics forum.
Audio/Electronics Forum
Old Jul 1, 2021 | 02:31 PM
Nursing Nevada's Avatar
Nursing Nevada
Issue:
I have the same issue that comes and goes as well.
Old Jul 2, 2021 | 12:54 PM
_chargedc6's Avatar
_chargedc6
5th Gear
I had the same issue after installing an aftermarket head unit in my Base Grandsport. Found most of the noise came from the worthless center dash speaker, so I disconnected it. Problem solved!
Old Jul 5, 2021 | 06:49 AM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
I had this same issue. I found that one of my wire connections was loose. No more hiss in my system. I had to go back over every connection one at a time to find it. Good Luck on your search.
Old Jul 6, 2021 | 05:15 PM
wtb-z's Avatar
wtb-z
That does not sound fun. What connection was the problem in your case?
Old Aug 5, 2021 | 07:52 AM
Maicol Pregnolato's Avatar
Maicol Pregnolato
I had same issue. Solved by checking all grounding points
To Hiss when speakers are engaged
