Overheating Issue
Old Jul 1, 2021 | 12:59 AM
Tobezzz's Avatar
Tobezzz
Default Overheating Issue
Evening team!
so I ran into an issue some weeks ago, and eventually gave up after running through you scenario. Began to have my coolant gauge dancing from cold to overheating, immediately I know gaskets are fine as it dances. At first it only happen at rare occasions but now it begins to dance up and down within 15 minutes of running. I change out the coolant sensor hoping that would fix my problem but it did not. Not much of a wiring guy so I immediately hit a wall with it.
If I can get any other scenarios to run, I would greatly appreciate !
least before I decide to take to a shop
Old Jul 1, 2021 | 10:47 AM
Chatman's Avatar
Chatman
Please describe dancing. Is it moving at a visible rate. Does it go from one to the other in a second? Do you get the same readings and change in readings using the digital display?
Old Jul 1, 2021 | 03:27 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
The ECT circuit is a basic 2 wire thermistor...the yellow wire is your signal wire and you have a sensor ground being the other...with the connector unplugged you should see a 5 volt reference on the yellow wire with the key on...the ECT sensor you changed will pull that 5 volt ref. to ground depending on the coolant temp...when the coolant temp rises the resistance decreases... if you were to take the 2 wires and jump them together you will see 280 degrees...just connector unplugged you will see -36 degrees...that yellow wire is most likely shorted to ground (chaffed wire to the metal frame) or to each other and that is why you are seeing the ECT jump around like that...you will have to inspect the ECT wires !!
Old Jul 9, 2021 | 01:52 PM
Tobezzz's Avatar
Tobezzz
wow !! You’re the best, I’ll definitely have to take a look at it over the wknd. I’m having cams/head work done a month from now too! So maybe I can wait for them to inspect the wiring while they have everything off 👍👍
To Overheating Issue
