Speedometer Not Working
Old Jul 5, 2021 | 11:07 AM
MikeMikeWmike's Avatar
MikeMikeWmike
Default Speedometer Not Working
My Speedometer just sits on zero. OBDII still picks up the speed reading as does cruise control but the dash speedo and HUD just sit on zero.
Since it's still picking up speed on OBDII and CC, I wouldn't think this would be a sensor issue.
Any ideas?
Old Jul 5, 2021 | 03:51 PM
Dano523's Avatar
Dano523
If ECM is pulling up the speed from the EBCM, since the speed sensors are connected to the EBCM, then problem is in the VSS wiring to the dash and Hud instead.
So on that note, would pull the ICP to check the VSS connector wire on the connector, since it sounds like the problem when an Hud was added to the car and spliced into the VSS wire/connector. If car came with Hud, then check the VSS wire up line to see if was cut or cracked isntead.
http://www.keystonestatecorvetteclub...%20Rev%202.pdf
