GS handling issues
Old Jul 7, 2021 | 06:57 PM
Chuck2012GS's Avatar
Chuck2012GS
Default GS handling issues
Hi Guys, I have a stock 2012 GS, took it to Limerock, it was dangerous. Was very unstable and very scary to go through fast corners,
so I was recommended to purchase shocks, I picked Bilstien R8s
still not happy with the rear end, feels unplanted, And wobbly. So I’m thinking of getting JOC sway bars, there are 2 models, I guess on stiffer then the other
i drive pretty aggressive on the track, used to race GT1, with SCCA
Anyone have experienced the same thing as me, and what was your solution
ty
Old Jul 7, 2021 | 07:09 PM
slowtealz28's Avatar
slowtealz28
How old are your tires?
Iceaxe's Avatar
Iceaxe
If your GS feels dangerous, scary and unstable in high speed corners I'm thinking you have another issue. Your GS should run through high speed corners like it's running on rails. High speed corners are one of the Corvette's strengths.
I'd get the car up in the air and start looking for what's wrong, broken or loose. Throwing high performance parts at the problem will not solve the issue unless you happen onto the current defect.
Anyhoo... that's my 2 cents, your mileage may vary.
Old Jul 7, 2021 | 07:29 PM
Chuck2012GS
hi thx for reply, I read a lot of guys on this forum complaining about the same issues
my car had 40k on it, shocks were original
I was talking to a guy at the track, he had same issues, sold his car and built a c5 Z06 into a race car
Old Jul 7, 2021 | 07:31 PM
Chuck2012GS
R88Rs for track
run flats fir street
Old Jul 7, 2021 | 07:54 PM
Chuck2012GS
R88rs are pretty new
run flats 3yrs old
do not use on track
Old Jul 7, 2021 | 08:12 PM
NYC6's Avatar
NYC6
As well as what some other stated here you should look at alignments if you haven’t already. A proper track alignment might set you straight.
https://www.corvetteforum.com/forums...t-settings.pdf
Old Jul 7, 2021 | 08:29 PM
Chuck2012GS
already did track alignment, it is definitely the suspension, I have raced cars and also track my SS1le camaro
the corvette’s rear does not feel planted
Old Jul 7, 2021 | 09:52 PM
gsflyer2011's Avatar
gsflyer2011
This. I even run track specs on street. Wears the insides a little faster than average but than i did not buy this car to save money on tire wear. It is set up where rear stays put no matter what. Turn and burn!!!
Old Jul 7, 2021 | 09:56 PM
Chuck2012GS
I do the same thing
both my cars are set up for track, and both are street driven
Old Jul 8, 2021 | 04:37 PM
GS_DAN's Avatar
GS_DAN
The BORG Delrin AF bushings really made my car feel planted.
Old Jul 8, 2021 | 05:22 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Stock GS should handle great. If it's feeling "wobbly and unplanted" you need to go over everything in the suspension. If you've already done the alignment, my guess would be you may have a worn bushing somewhere. My previous '13 GS was very planted and stable, and although the rear was a little vague on feel, it was a great handling car. Same for my current '12 ZR1. The stock C6 suspension is actually very good.
Old Jul 9, 2021 | 08:46 AM
AIR_RAM's Avatar
AIR_RAM
ty
I agree with the above.
If your GS feels unstable, its either the car or you. Assuming its not you and is in fact mechanical problem, I would look at the rear leaf and make sure its not broken... perhaps there are some loose bolts or worn out parts.
Your GS should feel very planted and give you confidence in corners... if its wobbling or shaking something is wrong.
Could it be your traction control? I know my traction control makes the car less predictable and very dangerous when trying to track it. That's almost caused me to loose control more than a few times.
To low of an air pressure in the tires could cause the rim to wonder in the tire... this can give an uneasy feeling when diving into or accelerating out of a corner... Heck the tail end even wonders left and right during WOT straight line acceleration if the tire pressure is to low. verify tire pressures are correct.
Shocks are another area that could be bad... if they are not controlling the spring return rate, that would also give a wavy unpredictable feeling in corners...
I'm betting something is worn or broken... Throw enough parts at it and your bound to fix it.
SPEED SAFE, NICK
Old Jul 9, 2021 | 09:01 AM
drewz06's Avatar
drewz06
thing knower
my first track day out i ran on 32 psi cold.... didn't think much about it until the car got scary on the track....
came in to the paddock and checked my tire pressure... i think all four were close to 48psi....
now i usually go on at 28psi and run a few laps to warm up, and come in and adjust.... i try to be right around 30psi hot....
that was on michelin pilot sports (new) and i even had to bring down the temps on my r888r's after driving them on the track for the first time...
that or your stock rubber control arm bushings are shot and need to be replaced....
Old Jul 9, 2021 | 06:19 PM
_chargedc6's Avatar
_chargedc6
5th Gear
What speeds does it feel unstable in the rear? Reason I ask is mine felt the same way the faster I went. APR 71" wing solved it.
Other than that, bushings and sway bars couldn't hurt.
Old Jul 9, 2021 | 10:19 PM
Chuck2012GS
SPEED SAFE, NICK
thank you all for responding
I have built and raced GT1 race cars, I know about cars, there is nothing wrong with the car, except it was not made to be driven like a race car, unless it is modified. I also have a 2018 Camaro SS 1le, I drive it like a race car, it handles great. I’m assuming that the corvette is mushy by design, for the street. I have done 20 track days with my 1le and have never been passed by a corvette, except full race cars or C7 Z06s.
I think most Corvette guys will never reach its limits. I am building it to be a serious track car. I have spoken to a few guys at the track with fast vettes, shocks, sway bars And a solid tranny mount are a must
i also cooked my stock 6 piston calipers, braking too deep, pedal went to the floor. So I purchased wilwood aero 6, race calipers and rotors, with 20mm pads, and I’m also putting in brake ducts. I will let you guys know how this works, I have been doing my homework, I checked the rear suspension, nothing worn or broke.
this is a video of me at Limerock, with my 100% stock ss 1le, I lapped the field and passed a 526hp Shelby GT 350 on last lap. As you see, I drive harder then most people
thank you
Old Jul 9, 2021 | 10:23 PM
Iceaxe's Avatar
Iceaxe
Meh... I somewhat disagree, something is wrong with the car or driver... but I've only won 2 national championships so WTF do I know... carry on...
To GS handling issues
Old Jul 10, 2021 | 09:23 AM
cyclesailor955's Avatar
cyclesailor955
I've driven a one day driving school in our 2011 GS at the National Corvette Museum track.
The car handled reasonably well for a mostly stock C6 for me. When Andy Pilgrim the instructor drove for a few laps he made the vette get-up and go.
Of course when you are a professional road racer you can make almost any car look good.
All four MRS shocks have been replaced and the Jim Mero Super Sport up grade has been updated.
The cars has Bridgestone Potenza run flat tires that did talk to me in the corners.Granted as to get serious a better tire and suspension upgrades are necessary without a doubt.
But for a weekend car that my wife and I can enjoy together, it ain't too Bad.
These cars are made to be Driven and Enjoyed !!!
Old Jul 10, 2021 | 12:19 PM
Chuck2012GS
well said!!
I love driving my car, on and off the track
Old Jul 10, 2021 | 12:21 PM
Chuck2012GS
in 65mph all the way up to 80s, felt very u stable. Yet on a autocross track, it’s amazing
