Steering Box Upgrade
Old Jul 8, 2021 | 04:56 PM
mongol7112000's Avatar
mongol7112000
Default Steering Box Upgrade
I'm looking for some guidance.
I'm upgrading my suspension in my 05 Z51 to LG GT 2 coilovers with front and rear sway bars.
https://www.lgmotorsports.com/gt2-coil-over-and-g1-sway-bar-package.html
I've own my car from day one off Kerbeck's showroom and the steering has always been a bit loose. Any suggestions would be appreciated.
Robert
Old Jul 8, 2021 | 05:46 PM
davidfarmer's Avatar
davidfarmer
Dial on more caster and set the camber in the aggressive end of a c6z setup. There are no aftermarket boxes available, although there are modified spindles the drifters use for significantly quicker ratios.
ive raced corvettes for 30 years so I like the oem ratio. What exactly are you trying to improve?
Old Jul 9, 2021 | 07:45 AM
mongol7112000
There seems to be a little play in the steering wheel.
Is that normal or something that needs to be addressed?
Old Jul 9, 2021 | 08:54 AM
drewz06's Avatar
drewz06
thing knower
i believe he means he can turn the wheel a little back and forth before the car starts to react to the input....
i've had this problem on other vehicles, but not either of my c6es....
unfortunately i have nothing productive to add.... good luck!
Old Jul 9, 2021 | 09:20 AM
davidfarmer
that isn't normal. Check the connection where the steering shaft bolts to the rack.... However it sounds like you might need a new rack. I don't think you need an upgrade, I think you need a repair/replacement.
Sorry I misunderstood your problem!
To Steering Box Upgrade
