Exhaust help
Old Jul 13, 2021 | 10:47 AM
rlarmore1981's Avatar
rlarmore1981
Default Exhaust help
I currently have a 2008 C6 manual transmission Z51 package car. I want to put long tube headers and a full exhaust on it, I live in New York, is there a way to make this combination pass OBDII emissions inspection? Visual inspection is not an issue just the plug in.
Old Jul 13, 2021 | 07:34 PM
NYC6's Avatar
NYC6
It will pass
Old Jul 15, 2021 | 03:33 PM
rlarmore1981
Should of specified it would be without converters.
Old Jul 15, 2021 | 11:21 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
Not sure hows your inspections are. But if you have a tune with no check engine light should be fine.
-Josh
Old Jul 16, 2021 | 03:36 PM
rlarmore1981
I was also looking for info about the O2 sensors. Is there a spacer or weld in port out there so that it will still have them installed. Pretty sure no tune is gonna eliminate the fact the O2 sensors are not installed
Old Jul 17, 2021 | 10:47 AM
grinder11's Avatar
grinder11
Without cats, I don't see how it will pass any smog test.......
Old Jul 17, 2021 | 10:51 AM
rlarmore1981
As long as the ECM doesn't throw an O2 sensor code, I can get it inspected. Hoping someone has a work around either a mechanical one or with tuning.
Old Jul 19, 2021 | 12:00 PM
D-Dub2013's Avatar
D-Dub2013
As long as there is no visual test done, when you have it tuned the tuner will tune out the rear 02s so you don't have a code so it will pass OBDII testing. The rear 02s will not affect how the car runs.
To Exhaust help
