LS2 headers vs intake manifold
Old Jul 21, 2021 | 06:33 AM
pab's Avatar
pab
Default LS2 headers vs intake manifold
I have a 2005 with a CAI and x pipe. My budget allows for one modification only at this time. Anyone know if an intake manifold (ie Fast 92 or 102) or headers would yield more hp gains?
Old Jul 21, 2021 | 07:33 AM
Kenny94945's Avatar
Kenny94945
I'd vote for the headers.
For the weight loss and sound improvement.
My reading recalls that intakes don't add that much power if the engine has a stock cam.
I think the headers will conservatively add 10 HP, the intake 1 or 2 HP.
Repeating I would add the headers and next add hi flow cats before an intake.
Once all done, then get a tune and I'd wager with the above mods and a tune you maybe looking at a 30 HP gain.
Good luck.
Old Jul 21, 2021 | 09:00 AM
Orion2011's Avatar
Orion2011
The LS2 benefits well from an intake upgrade. The LS3 does not.
OP could do the intake and not worry about tuning. Headers will require a tune.
EDIT: Long tube headers that is. Shorty's don't need a tune.
Old Jul 21, 2021 | 09:50 AM
pab's Avatar
pab
Default Pro tune
The plan is to have it tuned when it is installed. I take it that headers will yield the most power. Thanks
Old Jul 21, 2021 | 11:00 AM
da6speed's Avatar
da6speed
Headers first.
If you decide on an intake, do the Fast102, it will fit under the cowl.. I believe the fast92 has clearance issues.
Old Jul 21, 2021 | 01:39 PM
pab's Avatar
pab
Originally Posted by da6speed
Headers first.
Thanks. Any suggestions on headers?
Old Jul 21, 2021 | 08:07 PM
saplumr's Avatar
saplumr
You’ll definitely get more gain from headers. FAST will be 18+/-
Old Jul 22, 2021 | 06:36 PM
BigBlok502's Avatar
BigBlok502
I agree with others, headers first then a FAST. That's the order I did mine, in addition to a vararam. I have Kooks LTs.
Old Aug 10, 2024 | 08:37 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Diablo is the best of those style tuning devices -- Far superior then any handheld type-Depends on the mods on your car and if you run one of their canned tunes or have them specifically tune your car
For most applications Diablo is great
However if you want to go all out and are running a big cam and other major mods you best bet would be a custom tune with HP or EFILIVE-------
I prefer a "street driven" tune as compared to a dyno tune---With a dyno tune they do not drive the car for street ability ---idle quality or start up Just for WOT HP/TQ from about 4000-6500 RPM's-- No launch tuning----No trans tuning if it's an auto trans like shift firmness--shift point correction---TCC lock/unlock
To LS2 headers vs intake manifold
