Service Fuel System Light
Old Aug 12, 2021 | 04:09 PM
dcheinze1@gmail.com's Avatar
dcheinze1@gmail.com
5th Gear
Default Service Fuel System Light
I have a 2007 C6. My service fuel system light keeps coming on along with low fuel light. Even though I have a full tank. I have run two bottles of Chevron Tech injector cleaner through the fuel system. Still same issue. This is my first vette and I'm freaking out digging it so much. But this issue really is irritating.. Thoughts??
Old Aug 12, 2021 | 07:17 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Fuel
After you drive for 50 to 100 miles does the system go back to normal ?. If so, run it down to a quarter tank or slightly less and add a
Bottle of Techron Fuel System Cleaner and fill it up. Do this at least twice and report back with results. Sulphur buildup on fuel sensor. Running it down will make sure to get Techron into both tanks.
Old Aug 12, 2021 | 07:19 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
He literally just said he had done that.....
Worst case you need new fuel level sending units. The car isn't going to stop running or leave you stranded for this issue, assuming you don't run out of fuel (obviously )
Old Aug 12, 2021 | 07:31 PM
2008 Corvette
Default Fuel
Injector cleaner and fuel system cleaner by Techron are two different products. 1/4 tank or less will get it into both tanks when you fill up.
Old Aug 12, 2021 | 11:42 PM
dcheinze1@gmail.com
5th Gear
Is it safe to run a third bottle of Techron thru the system??
Old Aug 13, 2021 | 08:56 AM
2008 Corvette
If you are talking three at a time, I wouldn’t do that. Follow the instructions on the bottle.
Old Aug 13, 2021 | 05:23 PM
dcheinze1@gmail.com
5th Gear
What I meant was I have already used one bottle in a fill up and then a second bottle when I filled up again.
Old Aug 13, 2021 | 06:17 PM
2008 Corvette
Post #4. Let it get down to 1/4 tank or less. Pour in bottle fuel system cleaner. Then fill up. You may have to do this more then once. Report back after. once per fill up.
Old Aug 13, 2021 | 09:54 PM
russ472's Avatar
russ472
go to your tuner. ask him to uncheck the boxes that trigger the MIL light on the sending units. Your gauge will go back to operating normally and no more warning messages.
Then forget about it. did it to mine years ago.
Old Aug 14, 2021 | 11:42 AM
helga203's Avatar
helga203
This is yours. Time to change sensors or u can go the other way.
Old Aug 16, 2021 | 11:41 PM
dcheinze1@gmail.com
5th Gear
Thank you, but I must admit I have no idea what I'm looking at!
Old Aug 17, 2021 | 10:01 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
That is the fuel level sending unit found inside of the fuel tanks. It is usually what goes bad when the fuel gauge stops working
Old Aug 17, 2021 | 11:32 PM
dcheinze1@gmail.com
5th Gear
Okay, thank you.. As much as I was hoping for an easy fix doesn't look like that is to be...
Old Aug 19, 2021 | 11:55 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Unfortunately not. Getting the fuel tanks out in order to swap those out is not a fun job.
To Service Fuel System Light
