X Pipe vs H Pipe
Old Aug 28, 2021 | 10:38 PM
Big Red Ram's Avatar
Big Red Ram
Default X Pipe vs H Pipe
Going to add a Corsa Sport axle back to my 05 Base M6.
My question is should I change the H pipe out right away to an X pipe or is it not worth the cost?
The new system is 2.5" so no change in diameter.
Thanks for your input.
Old Aug 29, 2021 | 08:25 AM
4SUMERZ's Avatar
4SUMERZ
Depending upon the exhaust system, some use the different pipes for the sound. The H pipe typically offers a deeper hot rod sound, while the X pipe, a more exotic higher pitched sound.
Check wth the muffler manufacturer to see what they recommend for their system.
The X pipe generally offers an improved exhaust flow with equalized pressure on both banks which will increase power at all RPM's.
Old Sep 1, 2021 | 05:00 PM
Orion2011's Avatar
Orion2011
Corsa "claims" their X pipe is worth 5hp. I ran the stock H pipe for a couple years before springing for the X pipe.
Old Sep 7, 2021 | 01:45 PM
wood78221's Avatar
wood78221
I went from stock manifolds with stock H pipe/modded Flowmaster mufflers to LT headers, X pipe, with the same Flowmaster mufflers and it sounds different, for the better.
Old Sep 7, 2021 | 10:01 PM
Big Red Ram
ok here is a twist in this little project.
At some point my 05 base had an NPP exhaust added sooo its a 3" pipe from about a foot or 2 behind the cat all the way back.
To add my Corsa axle back to the existing system I would be going from 2.5 to 3 then back to 2.5 which seems really dumb. I didnt realize it was all 3" until crawling under there today and noting the difference.
Kind of hate to take a 3" system off and change back to a 2.5" system. My question is does it really matter in a stock engine to run 3"? I had read that unless you were running a turbo or supercharger that a 3" is a waste, is that true and if so then my Z06 NPP 3" could come off and pay for a good part of a 2.5" x pipe.
Old Sep 8, 2021 | 05:54 AM
wood78221's Avatar
wood78221
I agree on the X. Yes it’s higher for mine but does sound more exotic
To X Pipe vs H Pipe
