Bad Battery?
Old Sep 9, 2021 | 05:54 PM
TCKT B8's Avatar
TCKT B8
St. Jude Donor '09 & '11
Default Bad Battery?
I have a 10 year old Optima red top in my 05 C6. Forgot to put it on the battery tender and car wouldn't start (just the old click click click). so I charged the battery up to 13.1 volts and the car started (but barely). I drove it around for a while to charge it up then came home and parked it and it won't start. How can I be sure the battery is bad?
Old Sep 9, 2021 | 06:14 PM
BLUE1972's Avatar
BLUE1972
Take a voltage reading on the battery should be over 12 volts closer to 13 volts.
Old Sep 9, 2021 | 06:54 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
10 years old ???…you should have replaced it 4-5 years ago !!…take it to Autozone and they will load test it. I would just change it !!
Old Sep 9, 2021 | 08:59 PM
4SUMERZ's Avatar
4SUMERZ
Get yourself a new battery. Once it goes dead, recharging an older bsttery, the shock will loosen the deposits on the plates, they fall to the bottom, and short out the cells.
It's toast.
Old Sep 10, 2021 | 06:14 AM
BadAV's Avatar
BadAV
I had bad luck with 2 Red Tops, so I am not a fan. They take a special charging procedure when they have been drained, or many times they will not charge correctly. What I have read is that you take a regular battery, hook it up to the charger, then hook battery cables from the regular battery to the Optima. Once the charger says it's done, let the Optima cool down, then hook it back up to the charger to fully charge. It's probably worth trying. Or just get a new AGM battery since you already got 10 years from the Red Top.
Old Sep 10, 2021 | 10:32 AM
Iceaxe's Avatar
Iceaxe
If your battery is 10 years old it should be replaced... /End Discussion
Old Sep 12, 2021 | 06:48 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
C'mon....if the battery is 10 years old.... it's BAD!
Old Sep 14, 2021 | 11:07 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I think you got your money worth from the battery. Time to invest in another, don't want to be stranded specially at night.
Old May 2, 2024 | 11:38 PM
208vette's Avatar
208vette
Odyssey Extreme group 35
https://www.odysseybattery.com/extre...ies-batteries/
Old May 4, 2024 | 11:45 AM
RetroGuy's Avatar
RetroGuy
I usually replace Optima RedTops within 5 yrs or less. Great battery if in normal conditions and you have no parasitic draw. REPLACE.
To Bad Battery?
