what does the workshop manual states for the diameter range of the cylinder bore?
When is it out of range?
Initial bore is 103.251mm what is the max diameter before a larger bore and oversized pistons are required?
Any over bore need new pistone. Piston to block tolerance is 1.5 to 2 thou of an inch. And after market piston are diff depending on expansion. So go what insturtions with piston. Thats what i do. Never had a problem. U can hone with no change with piston or rings.
