Issues after harmonic balancer replacement
Old Sep 19, 2021 | 11:22 AM
Tonyalex's Avatar
Tonyalex
Default Issues after harmonic balancer replacement
Hi all,
help request please, I have just replaced the harmonic balancer (crank pulley ) in the U.K. , on my 06 C6 automatic , all went well, rack off, starter of , etc etc, rebuilt it all back up and all appeared well until I tried to drive it! The car will not change into second gear and cannot understand if there is a link to anything I could have done, the car has only covered 32000 miles and the gear box was working perfectly before this work was carried out, can anyone provide any advice as to what if anything I have missed
thanks in advance
Tony
Old Sep 19, 2021 | 12:02 PM
Sub8's Avatar
Sub8
Get a code reader on it.
Cam position sensor plugged in?
Old Sep 19, 2021 | 02:08 PM
Tonyalex's Avatar
Tonyalex
Ok thanks will get that done ASAP, just a mystery
Old Sep 19, 2021 | 02:09 PM
Tonyalex's Avatar
Tonyalex
Bit naive, cam sensor plug ?
Old Sep 19, 2021 | 02:20 PM
Tonyalex's Avatar
Tonyalex
Seen it under the starter will check thanks for your advice
tony
Old Sep 19, 2021 | 06:24 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Start
tony
Under starter is crank sensor. Cam sensor is on front of block.
Old Sep 20, 2021 | 10:54 AM
Tonyalex's Avatar
Tonyalex
Sorry my mistake, will get codes read tonight hopefully
Old Sep 20, 2021 | 01:51 PM
Tonyalex's Avatar
Tonyalex
Problem appears to be fault code P2723, pressure control solenoid 5 stuck off, code cleared and test drive now ok, thanks for all the help much appreciated
Old Sep 20, 2021 | 10:40 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
what steps did you follow for torque on the balancer?
Old Sep 21, 2021 | 02:58 PM
Tonyalex's Avatar
Tonyalex
Torqued old bolt to 240 ft lb, removed it , torqued new bolt to 37ft lb, and then a further 140degrees
Old Sep 23, 2021 | 11:29 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Are you fixing a wrecked vette?
Hope this helps on the transmission
https://www.obd-codes.com/p2723
Old Sep 24, 2021 | 02:35 PM
Tonyalex's Avatar
Tonyalex
Hi,
no not fixing a wrecked Vette, the opposite in fact, a mint condition 06, I have read the OBD thread and appreciate your help, all appears ok so will start with fluid/ filter change when parts arrive as a precaution
thanks again
tony
To Issues after harmonic balancer replacement
