Think I'm at the point very I'm ready to start modding my very close to stock '08 Z51 M6. The only mod currently is a Borla axle back. I was thinking about LS7 manifolds/cats/mid-pipe and a mild cam. This is 99% a street car, might one day see some HPDE, but right now it's almost exclusively a weekend warrior. Useable tq under the curve is probably the goal. I wanna keep it street able in terms of the cam, but really I'm interested in exhaust options.
I've researched on here the gains of the LS7 setup, but LT's provide better gains. I don't NEED to meet emissions, but one day that might change. I understand with LS7 setup that's not really a concern, with LT's I wouldn't mind swapping back to stock for a day IF I ever needed emissions.
Price is also a factor. Seems like the LS7 setup is the more affordable option. Last time I dealt with LT's was on my '02 WS6 and it was a nightmare because
I was 18 and inexperienced
TSP headers did NOT fit between the block and the car without removing engine mounts
so that makes me apprehensive of LTs, but I would hope a quality set would have a fairly simple installation and fitment. So if anyone has any input or feedback, I'd love to hear it.
Sounds like you have similar goals as I did. I installed a full Z06/LS7 setup in my '11 GS. I then gave it to Katech for their Stage II package, which includes a very streetable torquer cam, head work and some other goodies. You'll probably leave a few HP on the table going with the LS7 vs LTs, but I've been very pleased with the LS7 setup. It is quiet, no heat issues, fits perfectly, and looks stock should visual inspections become a concern down the road. Based on feedback from Katech, the LS7 setup showed very close HP/TQ numbers to what they have seen from other LS3's with LTs. I'm not sure if they had done a Stage II package on an LS3 with LS7 exhaust before, but they seemed a bit surprised at how well the LS7 setup flowed.
I managed to get a full LS7 manifolds-to-cans exhaust for $400 and installed the whole thing by myself in my garage on jack stands with hand tools in a day. I sold my stock cats and my NPPs for a $50 net profit, which covered a good portion of the cost of the O2 extensions and gaskets. When all was said and done I did the whole change out for about $20. Hard to beat that performance-to-cost ratio.
Hope that helps in your consideration of your options.
Gains of LT's over the LS7's are going to be dependent on the cam. The more overlap on the cam (i.e. the less streetable), the more the LT's are going to benefit you over the LS7's for peak numbers. If you're going for streetable over max effort, then you're not going to be able to tell the difference in performance except maybe at the track and even then only looking at the timeslip, your butt dyno won't be able to tell the difference.
C4 of Year Winner (performance mods) 2019
LS7/9 manifold setup gives a lot of the benefits with none of the drawbacks (heat, fit, passing emissions/visual check, etc). I did it on my previous '13 GS and loved them, and the car made just under 700whp when I sold it (blower). I've kept them on my '12 ZR1 (making 700whp), and there are plenty of ZR1 guys running them up to 800whp (where they seem to start being more of a restriction). I've had LTs on other cars, and it's just not worth the headache for the little bit of extra gain unless you're going for a max effort build.
I love everything I'm reading. Sounds like I'll definitely be going the LS7/9 route. I didn't know the LS9 manifolds we're also an option. Any idea where to look for these setups? I checked the parts/for sale but everything I saw was close to a grand for just manifolds and cats. I found the manifolds somewhere for $180, but can't find cats that are less than $500 a piece.
LS7 & LS9 exhaust manifolds are exactly the same. One catch when you're looking, there was a change in 2012 to the cat pipes and the x-pipe (added mini-cats to the x-pipe and changed the connector between the main cat pipes and the x-pipe). Cats are very hard to find anymore because of the recyclers buying them all up.
Interesting.......Brian Thomson@Thomson Automotive had a C6 Z06 he road raced. He tried a lot of combo's of LTs, though I am not privy to just what brand/tube size LTs he tried. But he told me the biggest power advantage he saw on the LTs over the OEM Z06 exhaust manifolds was in low to midrange torque. As for peak HP, he said the factory got the Z06 manifolds right, and they're are good enough that he only saw an increase of between 5-10 HP at peak. FWIW........
A quality set of headers going into the factory NPP mufflers is the best combination of loudness, power, quietness, and no drone in aftermarket headers (in my opinion). I think Kooks overall have the best fit and ease of installation. I had ARH and they do not fit as well and this is nearly unforgiveable considering the price.
Unfortunately I don't have NPP's. The previous owner put a Borla axle back on.
