C6 locked out
Old Oct 9, 2021 | 05:07 PM
losthope's Avatar
losthope
1st Gear
Default C6 locked out
Help! I have a C6. My battery is dead and alternator needs to be replaced. My trunk latch is broken. The shop I use told me I need to wire up to the starter from under the car to give enough juice for the key fob to come in and unlock the doors. But I have been trying for two days and it doesn’t seem to get enough juice or I’m not doing it right. Can anybody help. I’m moving in three days and have to get it in a tow truck but it’s stuck in my garage until I can get in it.
I NEED HELP 😭
Old Oct 9, 2021 | 05:14 PM
Moved to C6 Tech.
Old Oct 9, 2021 | 08:27 PM
4SUMERZ's Avatar
4SUMERZ
Welcome to the forum. Sorry to hear about your issue.
Hooking up booster cables + red to the positive starter post, and the - black to the frame and hooked with the same polarity to a fully charged battery should of given you enough juice for the FOB to open the door.
The other option is to get a towing service to come out with an air bladder that seperates the side window just enough from the weatherstripping to get a hook in there to lift the manual door latch near the floor, until it opens the door.
Good Luck
Old Oct 10, 2021 | 09:42 PM
Dano523's Avatar
Dano523
see that rear latch is broken, so access key is not going to work to get into the car.
Old Oct 18, 2021 | 08:48 PM
madgoal1's Avatar
madgoal1
what 4SUMERZ is trying to tell you is there should be a lever near/on the floor between the seat and the door. This is the manual way to open the door from the inside with a dead battery, need the air bladder to get enough space to get something to that lever to open
Old Oct 18, 2021 | 08:57 PM
ValenciaOrange's Avatar
ValenciaOrange
Break the window and you are in. Don’t do this. Call a locksmith and ask if they can help you get in your car. You might find one that can easily open your door.
To C6 locked out
