Air Intake Removal
Old Oct 27, 2021 | 07:01 AM
GMmuscle69's Avatar
GMmuscle69
Default Air Intake Removal
I'd like to clean the MAF sensor on my 2006 coupe. After loosening the throttle body clamp, I have been unable to remove the air intake tunnel. It looks like the two rubber grommets should pop free, but they don't want to budge. I'm concerned that if I force it, i may create a condition when I'm done that will allow the air intake to rattle or even move out of place. What am I doing wrong?
Old Oct 28, 2021 | 09:58 AM
Dano523's Avatar
Dano523
Is the air intake still OEM, or did someone install an aftermarket cold air intake like the Varoom, that is attached/runs through the bottom shield as well.
If stock system, then just use some silcone spray to loosen up the ***** through the rubber grommets.
If aftermarket cold air intake, then will need to unbolt the lower section that is attached/runs through to the lower sheild.
Old Oct 28, 2021 | 10:00 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Instead of messy silicone spray just use Windex on the bushings.
Old Oct 28, 2021 | 10:32 AM
Dano523's Avatar
Dano523
Thing is, the silicone spray will condition the rubber, making it easier to remove at a later time and lasting longer.
The ammonia in Windex will dry out the rubber faster once it dries, just makes the rubber harder/causing you to have to replace them sooner as they start to crack apart sooner.
Old Oct 28, 2021 | 03:37 PM
2008 Corvette
Dano. The silicone spray is messy. The Windex isn’t. Hence silicone spray requires clean up where Windex doesn’t. Enough said.
Old Oct 28, 2021 | 05:28 PM
GMmuscle69's Avatar
GMmuscle69
OEM intake. I used a trim/molding removal tool to get under the bushing and pop the plastic pin straight up. I was having a hesitation on full throttle about 2/3 up the power curve and thought I'd try cleaning the MAF sensor. I haven't had the chance to really open it up, but so far it's running fine. We're getting plenty of rain here in NJ, so I probably won't be able to find a back road for a few days.
Old Oct 28, 2021 | 08:26 PM
Dano523's Avatar
Dano523
Walmart for a spray can of super tech silicone spray, which dries in seconds and does not leave behind a wet mess of other additives in the spray that stay wet for hours.
To Air Intake Removal
