Harmonic Balancer gets me.
Old Nov 1, 2021 | 06:03 PM
Tim81's Avatar
Tim81
Default Harmonic Balancer gets me.
I bought this car in August in Ohio and it seemed fine. I did notice it had new belts on it I thought that was a good thing. Moved to North Carolina and started hearing a chirping noise coming from the front of the engine. Checked the balancer again and it was walking back and forth. There a lesson learned here somewhere. I think the balancer was bad when I bought it. Buyer beware.
Old Nov 2, 2021 | 06:30 PM
dondoucette's Avatar
dondoucette
I bought mine knowing it had a bad balancer, called the dealership for a quote while I was negotiating, used the quote to shave $2500 off the price of the car knowing full well I would replace it over winter.
Old Nov 2, 2021 | 07:37 PM
Kenny94945's Avatar
Kenny94945
OP, could be the balance was replaced, but the install was a failure.
Bolt issue, torque issue for example.
But then again maybe the new belts we masking the noise until the ball. finally fully failed.
If you DIY, good luck wished.
Old Nov 2, 2021 | 07:55 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
The OEM balancer is a POS ... Replace it with an aftermarket balancer such as a Dayco Powerbond Race Performance balancer.
That will the end of your problems
Balancer: $ 280
Labor: $700 (approx)
Old Nov 2, 2021 | 07:56 PM
Turbo6TA's Avatar
Turbo6TA
Is your engine a dry sump or a wet sump ?
Old Nov 3, 2021 | 09:26 AM
Orion2011's Avatar
Orion2011
I'm convinced the balancer will go bad on all C6's. When I did my heads/cam I also swapped the Balancer with ATI.
Old Nov 3, 2021 | 12:16 PM
Tim81's Avatar
Tim81
I can’t complain too much the car has 65k on it. Cost me just over $1,500
To Harmonic Balancer gets me.
