High idle after relearn
Old Nov 6, 2021 | 08:02 PM
B81jll's Avatar
B81jll
Default High idle after relearn
2007 corvette randomly started idling at 1800 rpm shows 20% accelerator reguardless how long it sets and idles.. have changed throttle body and accelerator pedal no change.. did accelerator relearn and car idle normal til pedal was touched then right back to 1800 rpm won’t idle down
Old Nov 10, 2021 | 07:13 PM
DallasVetteGuy's Avatar
DallasVetteGuy
Stock throttle body? How long have you let it idle at 1800? Is the car warm and idling at those speeds?
Old Nov 11, 2021 | 01:49 AM
B81jll's Avatar
B81jll
yes stock throttle body it’s ran for hours and also been driven probably 200 miles
Old Nov 11, 2021 | 10:50 AM
DallasVetteGuy
It could be a number of things.. Do you have HPTuners by chance?
Old Nov 11, 2021 | 12:20 PM
B81jll's Avatar
B81jll
yes sir I’ve looked over everything with it but I’m not good at reading the parameters
Old Nov 11, 2021 | 09:38 PM
gsflyer2011's Avatar
gsflyer2011
Make sure there are no related trouble codes in memory. If there are clear them and re do learn adapt. If it does not work, search CF, you have to drive the car at different speeds both HWY and city,? About 60 to 80 miles, not in different days and times but all at once.
To High idle after relearn
