LS7 Pushrod Length
Old Nov 17, 2021 | 06:46 PM
Jgreco24's Avatar
Jgreco24
4th Gear
Default LS7 Pushrod Length
I have a set of factory casting heads that I recently sent out to GPI to have fixed, ported and milled 0.20” while there. My question is after milling down 0.20” has anyone had to change to a shorter pushrod length? I plan to measure everything when the heads get back but I thought maybe somebody might know and I can get the parts ordered before hand. Any help would be appreciated!
Old Nov 17, 2021 | 07:29 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I guess you could go with a .025" shorter pushrod in order to get close to the same lifter preload as you had before milling the stock heads.
Just remember ... The total plunger travel inside the OEM lifters is .200" total (200 thousands) and that gives you a lot of leeway.
You would be just fine having the OEM LS7 lifter preload anywhere between .060" - .130" (don't have to be perfectly set to the exact midpoint which would be .100")
BTW ... I use pushrods that give me .090" preload (quiet valvetrain)
Old Nov 17, 2021 | 07:32 PM
Turbo6TA's Avatar
Turbo6TA
Certainly you mean you had the heads milled .020" (20 thousands of an inch)
To LS7 Pushrod Length
