Dual Valve springs or?
Cams from 590-600 lift
660 BTR Dual valve springs with tit retainers or
Pac Beehive 1218-19s
From my search of forums : One camp says the beehive might break so duals are insurance, other say the lack of bad harmonics/resonance and RPm capability make the beehive the choice for the smaller lift cams?
opinions?
Pac says the beehive... my tuner says dual springs.
opinions?
I've had a dual spring break and nothing happened other than me swearing to never buy another Tx Speed valve spring. I had a Comp Cams (918) single beehive spring break and it cost me an engine. Just changed a set of BTR .660 dual springs with titanium retainers and after 30K miles with a .620 lift cam, they still tested good. Think I'll stick with the BTR dual springs. I'd listen to your tooner.
When the Comp cams 918 spring broke, the cam was a mild blower cam. Something like a 222/230 116LSA with .580ish lift. I believe the cam was made by Comp also. Comp 918 spring failures were VERY common back when this happened. Comp gave me a new set of springs but didn't offer to pay for any of the engine damage.
When the Texas Speed dual spring broke the cam was a Cam Motion I had custom made. 218/230 118lsa with lift a little over .600. Tx Speed installed the springs on a set of their PRC heads. Texas Speed offered to give me 1 (one) spring and SELL me the other 15 at a reduced cost. They really stepped up, didn't they? I've been using the BTR platinums since then. I also told Tx Speed that I wouldn't hesitate to tell the story the way it happened. And I don't.
When I put a TSP 228R 600 lift cam in my C5 I used dual 660 springs and wished I had went with the pac 1218-19’s. Yes dual springs are good insurance but I feel like it was too much spring for that cam. In addition to giving up some horsepower they were super loud. I hate an excessively noisy valvetrain and those def made plenty of noise. If you plan on the car seeing a lot of high rpm’s then yea prob go with the dual springs but if you are like me and just did some occasional spirited driving then go with the 1218-19’s
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
My cam is a 220°/234° ..585"/.585" .118° LSA .Cam Motion custom grind cam in my PD 'Heartbeat' supercharged LS3.
Since the lift is less than .600" I am using the PAC-1218 'beehive' springs ... These are a 'drop-in' replacement spring for the OEM stock beehive springs that only have a seat pressure of 90 PSI
The PAC-1218 springs have a seat pressure of 135 PSI and an open pressure of 318 PSI, these springs are pretty easy on the valvetrain parts ... I only spin the engine to 6,400 rpm.
