Cooling mods
Also, don't forget to back flush the TVS-2300 heat exchange radiator out as well.
Now at this point, and if you do have enough mods to justify trying to keep the motor under 180*, then we can talk cooling mods.
Note, with oil temp not coming higher that that, it's not going to boil off the impurities that is will collect in the oil, meaning more oil changes will be needed to keep the impurities out of the oil that boil off at the normal temps instead. So the few HP that you will lose due to the motor running at normal temps (210~220), is well worth in the long run,so the oil will boil out it impurities instead.
As for C6 ZR1 unless you are high speed road coursing the car, or have over spooled the TVC2300 to turn it into a heat pump, Meth kit with 50/50 mix alone resolves those street heat problems of multi hit/pulls without having to break the bank on other needed items isntead.
Hence downside to the Elelbrock TVS-2300 is the single internal inter cooler itself to start with when its pushed, and why on the Maggy 2300, they were doubles up to hold cooler on a touch more boost isntead.
So yes, you can push the stock unit to 26lbs of boost on the motor, but since it's such a major heat pump at that pressure being spun up that much, better off just taking the 2300 unit off and replacing it with a TVS2750 instead. Hence at say 15lbs of boost and the 2750's larger volume, will not become a heat pump as fast as the 2300 at the same pressure instead.
The DeWitts in particular would help with not just keeping the coolant at a more stable temp but would also keep the oil cooler since the ZR1 has a block mounted oil cooler that is cooled by the engine coolant.
