Fuel system
Old Nov 24, 2021 | 12:30 PM
New Vette Man's Avatar
New Vette Man
Default Fuel system
Can anybody explain to me how the fuel system works in the C6 ? Does it draw from the passenger side first or what or does it draw from both tanks evenly?
The reason I asking is that I have a 3/4 full tank, and I would like to add a additive for the winter months storage here in Michigan. If I add the additive will it migrate to both tanks or just the tank I just added it to? I know this is the complete opposite of what should be done with the additive but this is the way I recieved my new vette.
I will decide on what to do based on your expertise!
New Vette Man
Old Nov 24, 2021 | 02:34 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
http://www.racetronix.com/Manuals/C5...escription.pdf
When you fill the tank the drivers side fills up then it spills into the passenger side via the crossover tube…if you put any fuel additive in wait till you have about a 1/4 tank or less…that way it gets into both tanks…also a good idea to buy a factory service manual or get a 3 year sub to ALLDATA or Mitchell for just the Corvette for around $50.00…also having a decent scan tool is helpful if you have any issues down the road…good luck !!
Old Nov 24, 2021 | 02:45 PM
torquetube's Avatar
torquetube
New Vette Man
A related topic is being discussed in this thread.
At 3/4 indicated your left tank should be full and your right tank should be about half-full. Any additive you pour in will splash into the full tank which will then overflow to the right. Does this result in sufficient concentration in the right tank? I don't know.
You could jumper the fuel pump which will energize the transfer system. Fuel will be pumped from right to left and then spill back to the right through the crossover tube. I'm not sure how long you should run it, but fuel transfers pretty fast. I've played around with the system and as I recall it can deplete the right tank in a matter of minutes.
To Fuel system
