Throttle Controller
I'm looking for a new Throttle Controller the one I have is causing the car to go into rreduced power mode with a code "Service Traction System"
Thus I had to unplug it!!!
Any recommendations for an affordable throttle controller???
CB
If I were buying a new TC today it would be the Soler Throttle Controller for the simple reason it works great and is a real bargain at $95.
https://www.solerengineering.com/gen...tors/se0839-tc
I also noticed Soler now has a Bluetooth version to compete with the Throttle Commander at half the price.
Basically a TC allows you to remap the throttle settings. From the factory a Corvettes throttle is only 30% open when the throttle is depressed 50%. I prefer to map mine so it's 50% at 50%, which mimics an old school carb and throttle cable. If nothing else most think they make the car more enjoyable to drive.
I may just try it - if it doesnt work, easy return to Amazon..........unless it causes the throttle to stick and shoves me and my Z into a tree and Im no longer around to do the return.
https://www.amazon.com/Controller-Un...xpY2s9dHJ1ZQ==
Throttle Response Controller.
wanted to post up my thoughts
this is on my 2008 Z06.
I had the Pedal Commander brand on my 2008 base and it really really made that car much more enjoyable.
the packaging and fit and finish of this Chinese brand is top notch. The connectors are top notch, OEM quality. I can’t imagine the US sold versions are from a different source- my guess.
so it works perfectly. I started around P2-3 and it was too much and actually raised the idle - I don’t recall my base C6 doing that. Maybe just difference between the two motors. Or could be this controller is just much more sensitive or settings provide differing levels of response.
I dialed it back to like P1-3,4 and idle is now normal and pedal response is awesome!
so for the price, id say go for it. Good thing about Amazon, easily returnable
Soler Performance LLC
support@solerengineering.com
(251) 468-9786
Any discount for forum members ?
