coilovers?
Old Dec 12, 2021 | 01:58 PM
oldnotslow's Avatar
oldnotslow
Default coilovers?
My 2006 with magnetic shocks has one that is leaking. I've been looking at coilovers from LG, Alden and BC. This is pretty much just street driving and it needs to lowered 2". Any recommendations? Also, is it better to turn off the magnetic shocks with Tech II or use the plug in devices to fool the computer??
Old Dec 12, 2021 | 03:42 PM
Dano523's Avatar
Dano523
Tech II to turn of real time dampening in the BCM RPO list so your not getting F55 error codes, and as for coil overs, unless you are tracking the car with enough talent to uses the small differences once they are set up correctly, then better off with either Bilstein B6's or B'8s.
The 6's are for a base car with slightly smoother ride, while the B8's are for a Z51 option car that will make the ride slightly stiffer, but handle better. If your looking for even better handling that the B8's, then DRM shocks, since they are B8's, but with improved dampening to keep the C6 even flatter in the turns instead.
Note, the Koni FSD are really good shocks as well if your thinking B6's, but a small fortune for the better chatter control on less than smooth surfaces over the Bilstein shocks instead.
Bluntly, the problem with coil overs with there small improvement over a trans spring set up that most can't feel or use, is that most don't have the talent to adjust them correctly in the first place, and don't end up with all that they have to offer in the end. Also, your into big bucks for a coil over set up that is fully adjustable in the first place (shock) to correctly dial in the car.
