First off yes, I did try searching the forum for this answer already. To be honest the searching on this forum really sucks or I'm not doing it correctly, either way I still need some info. My car is an 07 base BUT has the Z51 option as well as the JL5 and J55 RPO codes (I think those are the brake codes). My issue is I ordered a Wilwood rotor kit from Summit (Wilwood #140-9336D) and found that the rear rotors are to small I didn't even try the front. Yes I know send them back, already done. The kit states it's for a base model but clearly it doesn't fit. My rear rotor measures almost 13 inches. Summit is still scratching there head and Wilwood said they don't make a rotor that size for a base car. I'm thinking that the rotors for the Z51 are the same size a s a Z06 but without the calipers? Looking for someone to shed some light here.
Here is the size of the rotors on the C6.
Not sure what the GS sizes are.
Base
Front - 12.8" x 1.26"
Rear - 12.0" x 1.0"
Z51 optioned
Front - 13.4" x 1.26"
Rear - 13.1" x 1.0"
Z06
Front - 14.0" x 1.26"
Rear - 13.4" x 1.0"
BTW, I also find searching the forum using the search is hit and miss. I always ask the question on google putting C6 Corvette in the front of the search and that seems to get the forum thread hits associated with the question. As an example, try using google and put this in the subject line.
C6 corvette brake rotor sizes.
you will get hits.
The wilwood site has close to the correct rear rotor size of 13.0 x 1.1 for a Z51
but the front 13.4 is not listed. It has 14" x 1.25 or 13.06 x 1.25 which is closer to 13.4 of Z51
The Z51 setup was a GM anomaly.....slightly larger rotors with the same weak calipers. Marketing only. Track guys swapped the brackets and ran the smaller, yet cheaper and readily available base size.
First off yes, I did try searching the forum for this answer already. To be honest the searching on this forum really sucks or I'm not doing it correctly - - -
When using the Forum search do the Advanced Search. For really good searching use Google Advanced Search and point it to the Forum.
The whole confusion existing here is that Z51 is simply an OPTION on a base car, NOT a model.
The Z51 option includes J55 brakes. The J55 brakes (aka heavy duty brakes) were also available as part of the F55 (mag ride) option from '07 thru '13 and as a stand alone option on all base cars from '05 thru '13.
The standard brakes on all base cars was RPO code JL9.
