Cpr c6 radiator support brackets
Old Dec 31, 2021 | 12:56 PM
Cordes Performance Racing's Avatar
Supporting Vendor
Default Cpr c6 radiator support brackets
Over the years we have seen countless C6’s come in with the plastic upper radiator shroud broken in different spots. So we set out to make an aluminum fabricated setup will never break on you and add a little bit of flair to the engine bay. The kit includes two brackets (each side of radiator) and a middle plate that seals up the plastic shroud to the radiator. The holes are slotted to allow for variations on cars and we have verified fitment on C6 LS2, 3, 7, 9 cars. They also work with dropped down radiators which is common on ZR1 cars to fit larger air intakes such as the synergy unit or Kong.
Due to variances in cars you might have to slightly bend the passenger side AC line that goes next to the mount.
These are available in raw or black powder coating. Black coating is $30 extra and if you want that option just email us and we will get it switched over. Joe@cordesperformanceracing.com
https://cordesperformanceracing.com/...port-brackets/
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
