Cleaning the throttle body
Old Jan 24, 2022 | 03:33 PM
Sayfoo's Avatar
Sayfoo
Default Cleaning the throttle body
My '08 LS3 now has about 100k miles on it and the idle may be a little rougher than before. I put in new plugs at about 70k miles. It seems to run well and it doesn't throw any codes.
I bought a can of maf cleaner and plan to use spray the sensor.
While I'm there, I think I might as well check out the tb.
The web info is all over the place, from just spraying it while on the car, to taking it off in order to get both sides.
Some say it's ok to rotate the plate and some say it will screw up the positioning sensor and the computer.
I've also saw that if I hold the gas pedal to the floor and hold start button, the car will not start, but turn on all the electrics, and the throttle plate will rotate to the full open position. ????
Some say a new gasket is a must and others say that the O ring type gasket is ok to re use.
So, to those who have done it, what do you think??
Old Jan 24, 2022 | 04:40 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You don’t have to take the TB off !!…the area on concern to clean is the bore not the plate..that is what you clean !!…key off will work and if you want to disconnect the TB motor…video below should help !!…when you hold the gas pedal to the floor while starting this is called a “clear flood crank” and it inhibits injector pulse so the car won’t start !!…I clean my TB maybe twice a year and never had an issue with an O ring…just get Carb cleaner or TB Cleaner and an old toothbrush and clean that bore…just open the plate with your fingers.
Old Jan 24, 2022 | 06:06 PM
Dano523's Avatar
Dano523
Worry more about cleaning the Maf sensor, then cleaning the TB itself.
The TB only passes air through it, so light cleaning of it is more than enough in the first place.
If you still have the clean side of the PCV in play, it going to be oil fouled back up in a mater of weeks anyway.
Old Jan 29, 2022 | 10:25 PM
bwill03z's Avatar
bwill03z
Do not force the tb blade open with your hand, turn the ignition on but don’t start the car. Have someone press the gas pedal to the floor and it will open the blade. Spray your cleaner on a rag and wipe the tb out good. This is what I do at least.
Old Jan 30, 2022 | 03:37 AM
C5 Diag's Avatar
C5 Diag
What damage will forcing the throttle blade open by hand do ??…this is how I’ve been doing it for years on all different kinds of cars !!…you risk getting your fingers crushed cleaning it doing a “clear flood crank”…NOT recommended unless you can open the TB with a bidirectional scan tool…I don’t even like using that method.
Old Jan 30, 2022 | 09:39 AM
bwill03z's Avatar
bwill03z
well for one manually forcing open he butterfly plate can strip the gears… also it supposedly can screw up the positioning sensor.
Old Jan 30, 2022 | 10:26 AM
C5 Diag's Avatar
C5 Diag
The gearing inside the TAC motor is free to move key off so I don’t see how the gears can be stripped…the TPS sensor if that what you’re referring to are just 2 potentimeters inside the sensor…nothing that can get screwed up…you have your method but I’ll stick to mine !!
Old Jan 30, 2022 | 11:01 AM
BadAV's Avatar
BadAV
I agree. I have been cleaning throttle bodies by manually moving the butterfly since we had a 1992 Grand Caravan, and have never had an issue on any "brand". I generally do mine at least every other year as I find it keeps things running better at idle.
Old Jan 30, 2022 | 11:07 AM
bwill03z's Avatar
bwill03z
I mean if that has worked fine for you then I see no reason not to continue doing it, I was just sharing info that I’ve read many times over the years but if there’s no issues with manually moving the blade I may just start doing it that way myself
Old Sep 1, 2024 | 08:55 AM
KirillG88's Avatar
KirillG88
Hi, I know thats kinda old post, but I was cleaning my tb manually pushing the butterfly, and I think I've pushed it too far and now I think it changed its position, could this happen? Now , if I turn the ignition without starting the car and press the pedal, looks like the butterfly doesnt open 100%. Any chance I've screwed up its position?
Video attached:
https://files.fm/u/4y9xmuurdd
Old Sep 1, 2024 | 09:04 AM
C5 Diag's Avatar
C5 Diag
You should be able to open the TB plate fully manually with the engine off…if you can’t it looks like a bad TB.
Old Sep 1, 2024 | 09:34 AM
KirillG88's Avatar
KirillG88
I'm able to open it fully manually, but when the car is in maintenance mode with ignition on, if I press the throttle pedal so the maximum it opens like u see in the video. If im looking at the live data it shows it open max 56% , and when in idle it shows its 32.6% .
Old Sep 1, 2024 | 10:02 AM
C5 Diag's Avatar
C5 Diag
When you first cleaned it you were NOT in maintenance mode ??…I’ve cleaned many TB’s and have never had this happen…doubt it’s APP or TPS sensor issue but still may be something in the TB…I’ll look into this later.
Old Sep 1, 2024 | 10:23 AM
TonyCorvette_'s Avatar
TonyCorvette_
Don’t overthink the cleaning. I’ve sold hundreds of GM LS2/LS3 throttle bodies. I clean all of them all… blade, bore, casing; I recommend taking it off the vehicle so you can move the blade any way you want and actually get it clean. I primarily use water based degreaser and microfiber towel but for caked oil residue I use paint thinner. The electronics are sealed and TPS is mechanically linked to the blade. I’ve never seen an issue from this.
On aftermarket TBs, the TPS isn’t directly linked to the blade so I could see some rare issues with manually opening it causing the TPS to migrate.
I wouldn’t worry about any readings with the engine off. The TPS will read whatever motor input is from the ECM. Fire it up and check for codes, worst case, run a relearn or disconnect the battery for a few minutes.
Old Sep 1, 2024 | 10:24 AM
KirillG88's Avatar
KirillG88
When I first cleaned it I wasnt in maint mode.
Thanks, cplease let me know what to check
Old Sep 1, 2024 | 11:05 AM
KirillG88's Avatar
KirillG88
Car is running normally, without any errors. now throttle position when car started idle showing 13% and while driving if I push the pedal all the way down its shows 83.3 in the live data
Old Sep 1, 2024 | 12:47 PM
C5 Diag's Avatar
C5 Diag
What year is your car ???
To Cleaning the throttle body
Old Sep 1, 2024 | 12:49 PM
KirillG88's Avatar
KirillG88
I just noticed its C6 thread.
I have C7 grand sport 2017
Old Sep 1, 2024 | 12:52 PM
C5 Diag's Avatar
C5 Diag
YES !!…please post your concerns in the C7 Tech section as a NEW thread…avoid hijacking a similar thread !!…new is always best.
Old Sep 1, 2024 | 01:11 PM
PDsVettes's Avatar
PDsVettes
What is maintenance mode?
