TPMS Programming
Old Feb 7, 2022 | 03:41 PM
72greg's Avatar
72greg
Default TPMS Programming
I bought a set of wheels with tires and TPMS sensors installed for track use on my 2006 M6 LS2
In following the factory service manual process for programming I started at the drivers side front, pass front, pass rear and finished on the driver side rear.
On several attempts I was unable to get the 2 beep acknowledgement when I got to the driver side rear wheel.
When I started on the pass front and ended on the driver front, it gave me the 2 beep acknowledgement.
Not sure why it worked one way, but, not the other?
Any ideas?
Other than getting incorrect pressure readings from the DIC is there any concern/issue with leaving it the way it is?
Thanks!
Greg
Old Feb 7, 2022 | 03:44 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Follow this video ... It has always worked for me
Old Feb 7, 2022 | 08:57 PM
Iceaxe's Avatar
Iceaxe
No problem with leaving it the way it is. And the DIC is actually reading correctly as the first pressure seen is the first one recorded and around we go.
Old Feb 7, 2022 | 10:44 PM
Matt Zed's Avatar
Matt Zed
https://youtu.be/64-4mnwWwN0
Did you have to use that orange device or does simply adding air to a certain wheel during the process, trigger the TPMS sensor to communicate back?
Old Feb 8, 2022 | 12:44 AM
Evilbeard's Avatar
Evilbeard
that orange device is a programmer. basically it "excites" the sensor and pairs it with the vehicle. you can get them cheap on amazon.
Old Feb 8, 2022 | 01:10 AM
Matt Zed's Avatar
Matt Zed
The programming tool is cheap enough and will come in handy multiple times. Not too badly priced in this situation so I'll be buying one of my own.
There are so many versions of the EL-50448 for sale online, tough to know which to choose when buying.
Old Feb 8, 2022 | 07:57 AM
72greg's Avatar
72greg
I used this tool at each wheel
Amazon Amazon
I read numerous threads prior to posting my question, the definitive thread that I found was:
https://www.corvetteforum.com/forums...procedure.html
Old Feb 8, 2022 | 09:29 AM
Turbo6TA's Avatar
Turbo6TA
Here is the exact tool that they use in the video and also the one I bought (two sources for it below) (both Amazon and ebay)
https://www.ebay.com/itm/39333620666...QAAOSw8bZg5QzA
Amazon Amazon
Old Feb 8, 2022 | 12:26 PM
Matt Zed's Avatar
Matt Zed
https://www.amazon.com/EL-50448-Rele...%2C100&sr=8-19
thanks
Old Feb 8, 2022 | 01:45 PM
Turbo6TA's Avatar
Turbo6TA
The tool does not come with a battery ... You will need a single 9v battery.
Old Feb 9, 2022 | 09:58 AM
sramzzz's Avatar
sramzzz
^^^^^This^^^^^
Exactly what I used. I think I got mine for like $7.
Old Feb 9, 2022 | 10:52 AM
Turbo6TA's Avatar
Turbo6TA
I think I paid about $8 for mine about 2 years ago .. The tool has obviously gone up in price (inflation rears it's ugly head again).
Old Feb 9, 2022 | 04:44 PM
72greg's Avatar
72greg
I was attempting to do this in my garage - which is electrically very noisy.
I took the car into the driveway at least 50ft away from ANY electronics/electrical lines/dead batteries -
Left cellphone in the garage, nothing else on me except the tool.
Initiated the relearn sequence, left fob on the armrest, started on the correct driver front tire and ended on the driver rear - got the 2 beeps.
Success.
I'm guessing/pretty sure that the noise in my garage was interfering with the relearn sequence.
Old Feb 10, 2022 | 07:18 AM
davidfarmer's Avatar
davidfarmer
good work sorting this out! The RCDLR is THE Achilles heel of the C6! I had to put all 5 receivers back in my gutted race car just to keep it starting reliably
To TPMS Programming
