BASE/ZO6 GUIBO's
Old Feb 9, 2022 | 09:52 AM
jonjoy's Avatar
jonjoy
Default BASE/ZO6 GUIBO's
BASE/ZO6 GUIBO's does base have 10 mm bolts and the ZO6 have 12mm bolts? I am just about to do a torque tube job I would like to use A ZO6 drive shaft I have. Is there a way to make it work IF the bolt sizes are different?
Old Feb 13, 2022 | 02:05 PM
double06's Avatar
double06
I think all C6s have the 12mm giubos. The 10mm stuff was more in the C5s. The C6 ZR1 has a different giubo (its thicker) and can not be used on the regular C6s. That being said the 2005-2008 driveshafts shafts are one length and 2009-2013 are a different length. But giubos are the same.
