Alternator decoupler
Old Mar 31, 2022 | 12:53 PM
hubes's Avatar
hubes
Default Alternator decoupler
Do all C6's have the clutch on the alternator? Mine does not appear to. It's a 2009 base M6 that I've owned for about 4.5 years.
Also, what exactly does the decoupler do?
Here's a pic of my alternator:
Old Mar 31, 2022 | 01:01 PM
double06's Avatar
double06
I have a 2006 and I did not have a decoupler. I think they came in like around 2010 or so. The decoupler is used when you back off throttle (thus helping with belt whiplash) it kind of free spins like a torque converter.
Old Mar 31, 2022 | 01:05 PM
09LS3's Avatar
09LS3
I believe the were only installed on the auto trans cars.
Old Mar 31, 2022 | 02:18 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
For my 2011, the sales information for the GM ACDelco alternator P/N: 25888970 states that this alternator is used on both automatic and manual transmission cars (no difference)
Look at the description here: https://www.gmpartsdirect.com/oem-pa...nator-25888970
Old Mar 31, 2022 | 02:24 PM
Nowanker's Avatar
Nowanker
Pro Mechanic
My 2006 Z06 had the decoupler....
Old Mar 31, 2022 | 04:02 PM
HK770's Avatar
HK770
People also ask
What is the purpose of the decoupler pulley on the alternator?
An OVERRUNNING ALTERNATOR DECOUPLER™ pulley helps "synchronize" the belt drive system for improved engine efficiency, reduced Noise/Vibration/Harshness (NVH) and increased component life. When an engine accelerates, the alternator's mass creates resistance against the belt.
Old Mar 31, 2022 | 08:52 PM
hubes's Avatar
hubes
Does anyone have a manual trans car that they know came from the factory with a decoupler?
Old Apr 1, 2022 | 08:36 AM
grinder11's Avatar
grinder11
My C5 A4 has it, but the pulley looks much smaller than the one in the pic, unless it's an optical illusion (or fading memory)! I believe it helps with the serpentine belt chirping when the next gear engages. Never had one apart, so IDK if it works like a sprag clutch, or not.....
To Alternator decoupler
