Repair Broken A6 Shift Cable from Below???
Old Apr 17, 2022 | 02:02 PM
SkyKing421's Avatar
SkyKing421
Default Repair Broken A6 Shift Cable from Below???
I'm wondering if the broken shift cable forward bushing can be replaced from below. My son now owns the 2007 A6 coupe and is in Fla, about 500 miles away. He can do the "remove console and shifter" repair, but has not looked underneath yet. As I remember, there is a large aluminum stiffener plate, that covers the whole tunnel area. If that is removed, would it give you good access to the shifter/cable connection? Has anyone looked at it that way or even did it?
I'm probably thinking wrong, but it seems like it might be as easy as, remove tunnel plate, replace shifter bushing, replace tunnel plate, done!
Old Apr 17, 2022 | 03:37 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
A lot easier from the top.
Old Apr 20, 2022 | 12:22 PM
SkyKing421's Avatar
SkyKing421
Thanks, 2008Corvette.
I may have to drive down there to help get the repair done, but I wonder what is in the way from the bottom. Have you tried it?
Richard
To Repair Broken A6 Shift Cable from Below???
