Reverse Solenoid
Old Apr 30, 2022 | 11:36 PM
Dimitrios Arsoniadis's Avatar
Cruising
Default Reverse Solenoid
Hey Guys I'm sorry about the stupid question. I have searched and search the forums for a definitive answer and can not find one. some say its one way and some say its the other way. I'm using a tr6060 6spd manual transmission in a pro touring 69 Camaro build I'm doing. I cant get a definitive answer as to how the reverse lockout solenoid works.. Some say you engage power to the solenoid and this WILL allow you to go to reverse and some say that when the solenoid is powered it WILL NOT allow you to go to reverse. does anyone have a definitive answer as to how it works exactly. I'm gonna use a output from my Holley dominator Ecu to manage the solenoid just wanna make sure I understand how it works properly.
Thanks!
Old May 1, 2022 | 02:52 AM
Dano523's Avatar
Dano523
De-energized, to unlock it/ to allow the detent to be pushed in and allow it to go into reverse.
Old May 1, 2022 | 04:12 AM
Cruising
Originally Posted by Dano523
https://youtu.be/y4__IHHQbUw
Energized, to unlock it/ to allow the detent to be pushed in and allow it to go into reverse.
Hmm i wonder if i have a problem as i dont have anything wired up but am able to easily slide the shifter in reverse with the car off...
Old May 1, 2022 | 09:48 AM
helga203's Avatar
helga203
Thats how its supposed to be. When car on it energizers and it locks reverse so when ur driving u cant go into reverse when driving.
I forget what speed to activate solenoid when going forward.
When off is the same as if the connector is disconnected.
Old May 2, 2022 | 03:03 AM
Cruising
so basically if your driving the car lets say on the freeway for 4 hours that solenoid is active for 4 hours. isnt that really hard on a part like that?
Old May 2, 2022 | 08:59 AM
helga203's Avatar
helga203
U can drive the 100k hrs once u get pass the speed to active. thats what it is designed for.
The u cant take a trip anywhere. Put it n and forget about it.
To Reverse Solenoid
