No npp!
Old May 24, 2022 | 11:42 AM
Gunslinger1's Avatar
Gunslinger1
Default No npp!
Recently purchased a 2012 Grand Sport, I noticed that the mufflers do not have a vacuum switch installed.
Did they make units without the NPP feature? I'm thinking someone replaced the original equipment muffers.
The replacement mufflers aren't Corsa or Borla they appear to be factory installs.
What say you?
Old May 24, 2022 | 12:12 PM
ncnmra's Avatar
ncnmra
Do they have the valve, but no actuator, or no valves at all? I'm not sure if all GSs came with the NPP feature (other members may be able to chime in), but it is possible someone installed a louder exhaust, and then a subsequent owner reverted to a non-NPP stock setup.
Old May 24, 2022 | 01:13 PM
Gunslinger1
No valves at all present..My gues is someone replaced original set up.
Old May 24, 2022 | 04:11 PM
schizcat's Avatar
schizcat
NPP was still an option on the GS
Old May 24, 2022 | 04:12 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Yup ... in fact the NPP option was a pricey $1,195
Old May 24, 2022 | 04:45 PM
Gunslinger1
Wow! figured with a 4LT trim package NPP would be included...Thanks for the info..Looks like I have some Corsa Sports on my wish list
Old May 24, 2022 | 05:10 PM
farmington's Avatar
farmington
You can find npp axle back for under $500. A new Corsa or Borla is around $1500. You just need to get a npp in a box or just run vacuum line straight from intake to mufflers.
Old May 30, 2022 | 02:57 PM
Chiselchst's Avatar
Chiselchst
I have a 4LT '12 Grand Sport, without NPP.
If you want to check what the car came with from the factory, check out the build sheet. NPP is the option code.
I wound up using some ZR1 cans, and installed an after market vacuum kit with the remote control.. Very happy with it so far...
Old Feb 5, 2023 | 07:27 PM
RCR-X's Avatar
RCR-X
3rd Gear
Default NPP RPO but standard mufflers
I have a similar question. I just purchased a 2012 GS 4LT. The RPO sticker shows NPP as an installed option but the car has standard OEM mufflers. Are there any other physical indicators I can look for on the car that will give me a definitive yes or no for the option? If the car came with NPP I want to put it back on. Thanks
Old Feb 6, 2023 | 04:10 PM
C6VetteLover's Avatar
C6VetteLover
Pull the passenger tail lights out and look for a small module with vacuum lines connected
Old Feb 6, 2023 | 07:56 PM
RCR-X's Avatar
RCR-X
3rd Gear
Thank you for the tip. I’ll look this weekend. I made a few phone calls today to random Chevy dealers in my area. According to my VIN the car had NPP from the factory.
Old Feb 6, 2023 | 08:05 PM
C6VetteLover
Old Feb 6, 2023 | 08:54 PM
RCR-X's Avatar
RCR-X
3rd Gear
Gotta thank you again. Curiosity got the best of me and I pulled a light and checked. Just like you said and the video shows, my car is an NPP car. Time to hit up marketplace to find a pair. 😃
To No npp!
