I need to get my car into the shop to get looked at, but in the mean time, I was wondering if anyone can possibly identify what this might be so I have some sort of idea of what I'm dealing with. Obviously only so much can be figured out from an audio clip. This is on a cold start and you can hear it gets a bit louder towards the middle/end. It's not "as" noticeable when the engine is warmed up. Could this be a bad lifter possibly, or something else? '09 with ECS 1500 kit, cam, meth etc. Thanks!
I would first pull the valve covers and check all of your springs, rocker arms, and push rods. Could have a broken spring or rocker, maybe a bent pushrod.
If that all looks good, then yes, time to go internal and check the cam and lifters.
That is definitely a loud tap and not normal.
I agree, I had a broken rocker arm, Good thing we have a magnetic oil drain plug, got all the needle bearings.
Buddy had similar tapping.we took off valve covers and turned the engine to check every push rod to rocker arm and that's how we found the bad lifter. Rocker wasn't touching push rod by a 1/4 in. when lifter was down. Got lucky that was the only damage. When he heard the tapping he shout the car off emidditly. Thats probably why he saved the cam. Been 1000's already no issues. But every car and noise is different.GL
oof. lifter for sure. how many miles on motor ? MIGHT be able to fix it with 1 quart of marvel mystery. **** does wonders for the LS motors. Also, when was your last oil change? what oil and filter ?
Well I kinda figured it would most likely be a bad lifter. Hopefully the cam isn't damaged or anything else. I haven't driven the car in quite some time, in fact that clip was from last summer. I've sorta been avoiding it but I need to get it fixed already. Engine only has 32k on the clock and I've only used Mobil 1 Filter/Synthetic oil. Since I haven't driven it, it's been a minute since any oil changes. I doubt there's more than 1k miles on this oil but it's past due for one on time alone. I'll have to get it in to get looked at, though I'm sure this time of year it will be a bit of a waiting game. Thanks for everyone's help.
why so ? I've seen cured lifter ticks from MMO or Rislone. If the lifter is COLLASPED .....different story obviously. If the motor is sludge it's possible the hydraulic lifter isn't getting enough pressure. An oil change certainly wouldn't hurt. Plus then you can look for any bad signs ....ie metal from the cam.
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I personally wouldnt use MMO in my Corvette and hope it works. 6.00 snake oil could cause much more damage in the long run. And then what.
now maybe I’d use it on my 200k mile Honda or Toyota.
but. To chance screwing up my motor more on something like MMO is a big no.
Just curious, does it quiet down after the engine has run for several minutes? My LS7 has some pretty stiff dual springs, and on the first cold start of the day, 1 lifter won't pump up for 2 or 3 minutes. Even then, it's the only time all day it has that sound. Your tapping definitely sounds like a lifter. How stiff are your springs? How much oil pressure at idle, cold and hot? If your noise goes away after 3 or 4 minutes, I'd say your OK. I've lived with mine for 7 years now. Even changed the lifters once, trying to quiet it down, without success. If the noise doesn't go away, ever, I agree with the post about do not drive it any more until the motor comes apart. Look at it this way: If the noise is always there, the motor is gonna have to come apart. If you keep driving it, the motor will take itself apart. It's up to you how it comes apart....
MMO has fixed TONS of lifters on the silverado's. It is a well known issue, and common cure.
If the lifter stops making noise after a minute or so, it's probably OK. Regardless, the rockers and lifters need to be checked. If the lifter is noisy after a few minutes, it probably has collapsed, and needs replacement.
I am pretty sure the C6 pickup tube has an o-ring on it. That is also a very common issue, that causes oil pressure problems, therefore causing lifter issues.
change the oil and put in a quart of MMO. I bet you that lifter will cure itself.
Mine ticks too. These are noisy engines. Put a cam and longtubes and the ticking is amplified. I'd have a shop look at it for piece of mind. How does it run?
It's definitely still there even after the car is warmed up, just not as loud. I remember thinking I was hearing something in the beginning then it started to get louder and that's when I pretty much stopped driving it. Not sure on oil pressure off the top of my head because it's been a while since I drove it. It appears to run just fine. No codes or anything. Regardless, I am going to get it in to get checked out when I can. I could drain and check the oil but at this point I may as well just let the shop handle it since it's gotta go in anyway.
Did u ever figure it out I'm having a similar sound in me passenger side can't really hear it at idle but gets louder with rpms I've pretty much replace everything from lifters to pushrods and rod bearings aswell all the old parts looked fine aswell 😒 its so annoying to drive with that ticking noise it's driving me crazy
