Ls9 oil pump on ls7
Old Jun 4, 2022 | 01:42 AM
brandon1566's Avatar
brandon1566
Default Ls9 oil pump on ls7
Has anyone used an ls9 oil pump in an 07 z06? I've heard it puts out more pressure. Does anything need to be changed on the crank snout for it to work? Not really wanting to spend 900$ on a katech
Old Jun 4, 2022 | 01:20 PM
brandon1566
Bump
Old Jun 4, 2022 | 09:33 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
I did once, didn't notice any improvement whatsoever.
Old Jun 5, 2022 | 12:56 AM
brandon1566
thank you
Old Jun 5, 2022 | 09:10 AM
double06's Avatar
double06
You will get 20% more pressure or thereabouts. I had 45 psi at 200 degrees at 5,000 rpm it went to 53 psi at same parameters. On the earlier Zs you will need a different crank gear. Katech sells all the stuff.
Old Jun 5, 2022 | 11:21 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
More pressure isn't necessarily better, and it takes extra engine power to make it.
To Ls9 oil pump on ls7
