Premium fuel
Old Jun 23, 2022 | 08:34 PM
Kingstonontario's Avatar
Kingstonontario
Default Premium fuel
I have a C6 base model that calls for premium fuel. I'm taken a trip were there are very few gas stations that have premium fuel. If I don't accelerate hard and have no pinging, will it be safe to use regular gas?
Old Jun 23, 2022 | 09:36 PM
Rapid Fred's Avatar
Rapid Fred
Read your owner’s manual. The engine computers will adjust timing and pretty much eliminate pinging.
Do the stations on the way at least have 91 octane? That’s “premium” enough…
Old Jun 24, 2022 | 12:08 AM
Iceaxe's Avatar
Iceaxe
Where you traveling that doesn't have premium fuel? Nearly every gas station in the US has premium.
Old Jun 24, 2022 | 01:05 AM
topfuel67's Avatar
topfuel67
You can buy Lucas fuel injector cleaner/octane booster and add a couple ounces every time you fill. Higher octane is basically more additives that reduces the harsh explosion in pure gasoline.
Old Jun 24, 2022 | 07:50 AM
Spaceme1117's Avatar
Spaceme1117
Not true. Many areas in states on the left coast (Pacific Ocean, not the other left coast, Atlantic Ocean), will only have 90 or 91 octane available. I think I recall seeing a few years ago 85 octane at some gas stations there as well.
But yes, if you are stock, you can definitely run 87 and it will be fine. The computer will compensate.
Old Jun 24, 2022 | 07:54 AM
Iowa's Avatar
Iowa
Can be very hard to find in rural Iowa. 87 to 89 octane is the norm. My trips are planned ahead so I know where I can get 91 octane.
Old Jun 24, 2022 | 08:46 AM
Cap'n Pete's Avatar
Cap'n Pete
When I was ~20 and broke because all of my money was being spent on payments & insurance for my '02 Z28 (LS1), I often ran 87 octane for just cruising / commuting. Esp. in cooler months when the colder fuel is moderately more resistant to ignition than when it's hot summer weather. I could definitely hear the engine knock/ping at various loads/RPM's though, so the knock sensors were absolutely being put to work. As time went on and I could afford to consistently run 91 or better, then I did. When I retired that car with ~150,000kms (~93,000 miles), it ran like a top, made great power, and didn't burn oil. I abused the hell out of it, at the 1/4 mile and at the road courses in Ontario.
So yeah, a road trip with your LS2 or LS3, running 87 on occasion, as long as you're not pushing it, won't hurt the engine. I wouldn't recommend taking a car to the track and testing the knock sensors out in that manner, but for gentle street cruising, they can generally keep up.
But with the long-distance range these cars have while highway cruising, I'd be surprised if you couldn't find a station with 91 somewhere along your travels. I took my 2010 on a trip to the east coast (~5k round trip) and never had to run 87.
Old Jun 24, 2022 | 09:17 AM
tommyc6z06's Avatar
tommyc6z06
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
for a long gentle cruise, I'd be more aware of lugging the car at low rpm in 6th, but you can always carry a can of this and add if you can't find 91.https://perryautolaval.com/collectio...octane-booster
Old Jul 24, 2022 | 10:14 PM
Kingstonontario
FYI to all. I just drove over 6000 Km using regular gas on my trip, northern Ontario. I did a lot of passing with very little trouble. When I got back home I filled up with premium gas, what a hell of difference. I feel totally confidence in using regular gas in certain situations as the computer totaling looks after everything .
This car is totally a pleasure to drive.
Old Jul 25, 2022 | 12:03 AM
JackDidley's Avatar
JackDidley
How was the fuel mileage when using cheap gas ?
Old Jul 25, 2022 | 10:37 AM
Kingstonontario
8.2 liters / 100 Km. Which is about the same as using premium gas.
Old Jul 25, 2022 | 02:11 PM
JackDidley's Avatar
JackDidley
I really thought it would burn more fuel due to slower timing .
Old Jul 25, 2022 | 02:32 PM
farmington's Avatar
farmington
Actually lower octane fuel burns faster than premium. An engine that doesn’t need premium will make less horsepower on premium than on regular.
Old Jul 25, 2022 | 02:49 PM
Orion2011's Avatar
Orion2011
The ECU will detect knock and pull timing. Performance and fuel economy will suffer but no damage will be done. Use the highest rating the station has.
Old Jul 25, 2022 | 02:54 PM
Orion2011's Avatar
Orion2011
Octane is the measure of a fuels resistance to ignition. High compression engines need octane to prevent pre-ignition aka knock. Octane is not a measure of a fuels energy content.
Octane gets associated with mo-power due to it being used in conjunction with high compression. The compression is where the mo-power comes from by making the engine more efficient.
Old Aug 25, 2024 | 11:04 AM
57gman's Avatar
57gman
[QUOTE=Spaceme1117;1605317918]Not true. Many areas in states on the left coast (Pacific Ocean, not the other left coast, Atlantic Ocean), will only have 90 or 91 octane available. I think I recall seeing a few years ago 85 octane at some gas stations there as well.
Not trying to start trouble, this is one person's opinion. I live in PA, hills all over the place, I'd like to hear more opinions. Would it "ping" with lower octane ( cheaper) gas and loose power?
Old Aug 25, 2024 | 11:10 AM
woodsdesign's Avatar
woodsdesign
I just filled up with 89 octane and drove around 285 miles back from Carlisle Pa. with no issues what so ever.
Old Aug 26, 2024 | 09:18 AM
Dreamer2's Avatar
Dreamer2
So I use 94 Ultra. Does the cost get to a point of diminishing returns compared to 91-93?
To Premium fuel
