If you're referring to the rear axle hub, I used the Moog about 6 months ago. I think they were $74/each. It's probably a good hub assy. I've had no problem. Delco is about the same price. Delco is made in China; Moog is made in Taiwan.
I've always used the SKF hubs on C6s when they needed to be replaced. Haven't had any issues with one yet.
This is a ME TOO! I've used the cheaper hubs in the past but you get what you pay for. China, Taiwan I don't think it matters any more. Most everything is made in China the Good parts and the cheap parts. I recently replaced all of my wheel hubs with SKF, got tired of changing out the cheap junk. Good Luck.
Timken originally were made in USA....They are still made by USA company...Moog will be a rebranded from someone else and SKF is Japanese but could be made anywhere...Frankly in todays world any of them could be rebranded or even worse... knock-off's...(which you really don't want and make sure they are genuine before you put them on no matter which brand)
I had to replace one in my 2012 due to speed sensor failure (bearing was good but sensors non serviceable) and I used Timken...but I am biased after working for them for more than 45 years and I know first hand how well they are engineered...
I found a MOOG on sale. I'm going to try it first on the bearing I know is bad. If I have to do any more, I will probably try the SKF.
Yea I did basically the same thing you are going to do but with another cheaper brand. 2 years later I replaced them all with SKF. My cheapo was a rear passenger i believe and not so easy to replace. My suggestion is to do it right the first time because you will do it again.
If 3 people tell you that you are a horse, it's time to look in the mirror.
