Help finding parasitic draw
Old Aug 3, 2022 | 07:27 PM
Regular_Punch's Avatar
Regular_Punch
Default Help finding parasitic draw
Never done this before but I have done a little research and have a few questions.
Z06, battery is in the trunk. Where do I hook the amp meter to keep the car from waking up? I'm guessing that every time I pull a fuse, I'll have to wait for the car to sleep again?
I've already pulled the onstar fuse, battery still dyeing (new battery). Battery stays charged if car is driven every day.
Old Aug 3, 2022 | 07:47 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Pulling fuses is not the best method to do !!…voltage drop across the fuses is the best way…watch the video.
Old Aug 3, 2022 | 07:53 PM
wjnjr's Avatar
wjnjr
In for the fix
Old Aug 3, 2022 | 08:16 PM
Regular_Punch
Thanks for the video! I think I'm going to give this a shot tomorrow.
After digging some more, I may have found an answer though. My car has a M2W switch and it's hooked up in a way that draws current when the exhaust valves are closed. I would say that is almost certainly the cause because there are no other electrical issues with the car.
Old Aug 4, 2022 | 11:06 PM
gdmoore01's Avatar
gdmoore01
This will do it. I have since learned to set my M2W switch to "Off" before shutting down the car, as instructed in the attached M2W documentation.
GD
File Type: pdf
Old Aug 5, 2022 | 07:49 AM
Raffman55's Avatar
Raffman55
2024 C6 of the Year Finalist - Modified
2018 C1 of Year Finalist
Yes ! Found the same problem on mine.
To Help finding parasitic draw
