Question about hi-flow cats.
Old Aug 8, 2022 | 06:58 PM
SK '08's Avatar
SK '08
Default Question about hi-flow cats.
Over the weekend, I finally upgraded the stock exhaust, w/ a Pypes Violator axle-back system. Since it's basically a one piece system, I didn't want to tackle it myself, so I had a dealer just right down the road install it. So, after driving it around a bit this past Sat. I have to say I am a lil' bit disappointed. It is deeper (which is good) and like, maybe only 25% louder than stock. (which is not good)
I know it's not the Pypes system to blame, but rather the stock exhaust manifold and cats. ( I had a 2011 Mustang GT that had tubular headers from the factory, + a Roush axle back system, that I installed & it was loud !)
So, could LG hi-flow cats alone (w/ stock exhaust manifolds still on) give me that extra little bit of sound I'm looking for?
Now I ain't want long tubes, because it is too much hassle time wise& price wise. Plus, you need tuning to go w/ that.
So, what do some of you exhaust experts have to say? I welcome and appreciate helpful info!
Old Aug 9, 2022 | 05:56 AM
SK '08's Avatar
SK '08
Or maybe I should start hunting down a Z06 exhaust manifold setup instead?? Hmmm.........
Old Aug 9, 2022 | 08:50 AM
schizcat's Avatar
schizcat
You may get a little more sound but not sure it would be worth it. You would have to have a shop do a custom exhaust job to get the cats installed. This may also add to a slight increase in sound. Any reason for not going with a full long tube set up? Here is a thread that was opened a few years back. About 6 or so posts down there is an option for cats for stock exhaust.
https://www.corvetteforum.com/forums...-question.html
Old Aug 9, 2022 | 11:27 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Hi-flo cats in addition to what you now have won't make that much difference. If you're really after a louder sound go with headers & then x-pipe with hi-flo cats. I'm running American Racing headers with their x-pipe/hi-flo cats & Corsa Sport exhaust. Outstanding exhaust note & really cool crackle & pop on downshift!
Old Aug 10, 2022 | 06:10 AM
Spaceme1117's Avatar
Spaceme1117
A complete Z06 exhaust system with the NPP mufflers would make it sound a lot better.
Beyond that, a proper set of long tube headers (Kooks are the best), X-pipe, hi-flow cats going into a factory NPP is the best of both worlds; quiet when cruising, loud when you stick it. Everything else is just pissing in the wind.
Old Aug 11, 2022 | 10:23 PM
iwantaz06now's Avatar
iwantaz06now
Dump that China junk and get yourself a max volume system like Corsa Xtreme or Borla Atak. I run Corsa Xtreme because it controls drone way better than the Ataks I had. Bigger 4.5" tips and they are a little lighter than oem too.
Old Aug 13, 2022 | 12:27 AM
Sid1231987's Avatar
Sid1231987
You never going be loud with cats 🤦🏼‍♂️
I recant my statement. Mark posted a video that proved me wrong. They definitely have come along way
Old Aug 13, 2022 | 12:30 AM
iwantaz06now
I wouldn't go that far. You can be loud with cats:
#corsaxtreme
Old Aug 13, 2022 | 12:51 AM
Sid1231987's Avatar
Sid1231987
https://youtu.be/xa9lAvoSnRo
#corsaxtreme
dump valves in front of the cats as well. I just don’t buy into the high flow cats. Plus if you don’t have them nobody can steal em from under your car. Why I’m 0/3 on cats and 1/3 with mufflers.
only car I have w mufflers are the Corsa extremes lol
Old Aug 13, 2022 | 05:46 AM
hubes's Avatar
hubes
I don't believe anyone makes bolt in high flow cats. But if you did find some or get some made, you'd probably want a tune to turn off the secondary O2 sensors because you'd likely get a code without it
Old Aug 15, 2022 | 06:28 PM
Wirelessinc's Avatar
Wirelessinc
Banned Scam/Spammer
correct
To Question about hi-flow cats.
