Cam questions
Old Aug 19, 2022 | 02:42 PM
blownbayou's Avatar
blownbayou
Default Cam questions
About to pull the trigger on a cam and was wondering if anyone can shed some light on these specs???
220/232 116+5
2011 A6 Base LS3
STOCK EXHAUST Bi mode NPP (reason for staying stock is NO exhaust smell wanted)
STOCK CONVERTER
Retune of course
I know the power numbers will be half of what it would be with full exhaust, but not really worried about that........
Old Aug 19, 2022 | 02:54 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Originally Posted by blownbayou
2011 A6 Base LS3
FYI ... You will get very very little (if any) exhaust smell from a set of headers as long as you order them with cats.
Old Aug 19, 2022 | 03:05 PM
blownbayou's Avatar
blownbayou
I have read mixed reviews..... Coming from a 2000 z28 with all the mods, I know the smell was there and the wife hated it.
I want to be sure there is no smell with this cam swap.
I also have read (and it makes sense) that even if you have a catted I pipe, the cats are too far away and do not heat up fast enough on initial start up...Causing the smell for a time.
Maybe down the road for the headers, but I miss the lope of my Z28
Old Aug 19, 2022 | 03:16 PM
schizcat's Avatar
schizcat
Cant speak for the LS3, but my 05 has a little bit of an obnoxious exhaust smell with long tubes and hi flow cats. If it was a daily driver, it would be a little too much for me. If you are worried about the smell, look for a good set of LS7 exhaust manifolds.
As for the cam, the intake\exhaust is pretty mild. 116 LSA may be better off with a SC car. It will also be shifting at a higher RPM even with the tune. Others may step in who know more on the auto side but you may want to upgrade the convertor as well.
Old Aug 20, 2022 | 12:23 AM
Corse46's Avatar
Corse46
i have a BTR stage 2 with ARH and high flow cats, dyno tune, and stock NPP… there is definitely a smell all the time. It’s not bad and it doesn’t bother me, but there is definitely not zero smell.
Old Aug 20, 2022 | 08:27 AM
Turbo6TA's Avatar
Turbo6TA
I think the increased exhaust smell has just as much to do with a 'bigger' cam as it does with having headers with cats.
My LS3 had very little exhaust smell after I installed a set of headers with cats and a tune (and this slight exhaust smell was only evident when the engine was still cold) ... but, after installing a cam, I noticed more exhaust smell.
I believe, the more overlap the cam has, the more exhaust smell you will notice during idle.
Old Aug 20, 2022 | 09:41 AM
farmington's Avatar
farmington
I would seriously consider a GOOD converter with any camshaft, though. Doing a yank ss3600 with my btr2 cam and full exhaust
wont be much lope with that cam, obviously.
Old Aug 20, 2022 | 01:51 PM
Petera90's Avatar
Petera90
That cam sucks. So much advance ground into it. 100% would not do that cam. Plus 116 LSA is whimpy for n/a. It’s whimpy even for boost…
I would do a 218/228 114+2 .595”/.595” to keep dynamic compression up. It’s gonna feel like a turd with more intake duration. This spec will keep you at negative 5 overlap and will idle stable at 650rpms with good tuner. Slight lope at idle. This cam will make more power everywhere. You won’t beat the **** out of your valvetrain. Run a Trunnion upgrade and since lift is under .600” you can run some .625 beehive springs from pac. This cam is not too big where it needs exhaust upgrades to scavenge.
I have arh headers with cats and still stinks. I would also do a converter down the road.
Old Aug 20, 2022 | 02:44 PM
farmington's Avatar
farmington
Check out the just released btr cams. Stage 1 and 2
Old Aug 20, 2022 | 03:23 PM
Petera90's Avatar
Petera90
the new stage 2 has 8.5 degrees of overlap and new stage 1 has 1 degree of overlap. Kinda annoying they don’t disclose cam specs.
Old Aug 20, 2022 | 03:26 PM
jamieo's Avatar
jamieo
All the specs are on the BTR website.
Old Aug 20, 2022 | 04:12 PM
Petera90's Avatar
Petera90
Go look at all the “new” cams on their site. All have same specs… I already called and asked. New v2 has 8.5 degrees of overlap. It’s kinda annoying how they hide it with an “x”
Old Aug 22, 2022 | 09:35 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
Stock convertor I would either go with BTR stage 1 or 2 or the TSP stage 1... all great options. I have the BTR stage 2 and love it, had the TSP stage 1 before and also a great option (had a lifter failure knock it out). BTR stage 2 seems to have a much broader powerband than the TSP 1. Cam motion and GPI both offer stock convertor solutions as well. I've heard the GPI is more on the radical end but cant confirm or deny.
Old Aug 23, 2022 | 01:49 PM
blownbayou's Avatar
blownbayou
Got my parts coming in....I am in GREAT hands with Futral down here in Louisiana. He has done a good amount of work for me and never misses. I told him what I wanted (drivability with stock items) and I have no worries with his tuning and experience.
Will post cam specs, numbers etc when I get em.
Also thanks to silver08z51 for his input and vid clips.....
Stoked and ready for the chop
To Cam questions
