Oil temp range and 10w-40
Old Aug 20, 2022 | 03:58 PM
H82GOSLW's Avatar
H82GOSLW
Default Oil temp range and 10w-40
I picked up a ‘09 base C6 about a week ago. It’s H/C/I and runs real strong. Today was 90 degrees out and I was out driving around and noticed oil temp about 240….seems high to me. (Wasn’t getting on it at all). Second time this week I saw that temp. Guy I bought from has been running 10w-40 in it and changed it religiously.
Thoughts on the high temps and the type of oil?
Old Aug 20, 2022 | 04:14 PM
davidfarmer's Avatar
davidfarmer
That is very high for street driving. Oil cooler? Check front coolers for grass, it can get packed in between the coolers
Old Aug 22, 2022 | 01:18 PM
H82GOSLW's Avatar
H82GOSLW
Everything looks clear. I’d love some more feedback on the different oil being used. Thoughts?
Old Aug 22, 2022 | 03:19 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Factory spec is 10W-30 so why use something else? All sorts of "urban legends" floating around claiming higher viscosity oil is "better" for street cars....go figure.
Old Aug 22, 2022 | 07:41 PM
C6VetteLover's Avatar
C6VetteLover
Change the oil to 10w30 synthetic and check for debis in the coolers
Old Aug 22, 2022 | 08:45 PM
H82GOSLW's Avatar
H82GOSLW
Car calls for 5W-30. Why are you guys saying 10w-30? Did different year LS3s have different oil?
took it out again tonight with temp around 74. Car still got up to 220 and I was not getting on it at all.
Old Aug 22, 2022 | 09:11 PM
bwill03z's Avatar
bwill03z
As far as the oil idk why these guys are saying 10w30, the factory fill is 5w30 and that’s what I would use… I would not use 10w40.
As far as temps that does seem a bit high but then again you don’t have an oil cooler and it was super hot out when you were seeing the 240 temp. In my 2011 base I didn’t check it often but I know it would jump to 220 real quick and that was with pretty normal driving, not feathering the pedal but not ripping on it either.
Old Aug 22, 2022 | 09:52 PM
HK770's Avatar
HK770
You might remove the plastic upper radiator support and check/clean between Radiator amd condenser. You might check that fan is acutally turning on and the fan plug for burning/melting.
And as far as useing 10-w30 oil the Ls engine is not Bearing Clearanced to use it.
Old Aug 24, 2022 | 10:39 AM
H82GOSLW's Avatar
H82GOSLW
Was out the other night….74 degrees ambient temp and oil temp was up to 219. I’m going to switch back to 5W-30 asap and see what that does. Also rechecking the areas mentioned above. Thanks to all who posted for the help.
Old Aug 24, 2022 | 11:00 AM
bwill03z's Avatar
bwill03z
Im sure that 10w40 is causing it to run a little hotter. Switching to 5w30 should help some
Old Aug 25, 2022 | 11:57 AM
gdmoore01's Avatar
gdmoore01
Sounds like you may not have a copy of the 2009 Corvette owners manual. Attached link to a DL PDF. Will provide most of the answers you seek.
https://cdn.dealereprocess.org/cdn/s...9-corvette.pdf
Enjoy your car...GD
Old Aug 25, 2022 | 12:39 PM
Dave S's Avatar
Dave S
My bad....brain fade. Factory spec is 5W-30.
Old Aug 25, 2022 | 01:44 PM
slowtealz28's Avatar
slowtealz28
My car is a grand sport so it has the coolers, in 95* south florida heat I have to really TRY to get my oil temps above 200*. Coolant temps are a different story, will routinely get up to 220 if in stop and go traffic for more than a few minutes.
Old Aug 26, 2022 | 11:25 AM
sccaGT1racer's Avatar
sccaGT1racer
Just driving around your oil temp should not be getting that high. When you change the oil drain into a clean container. inspect for metal in the oil and the oil filter. What was your coolant temp when the oil was that hot?
Old Aug 31, 2022 | 09:13 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
any input why i have been told with a cam to use 10w30 or 10w40? Seems OP original owner was told the same.
Old Aug 31, 2022 | 09:46 PM
bwill03z's Avatar
bwill03z
I don’t see any reason to run a 40 weight oil unless you’re tracking the car. To me 5w is always better than 10w because the faster you can get oil to moving parts the better because the majority of engine wear happens on cold starts. I’m no oil expert tho so if I’m wrong someone please educate me. You’ll lose a little bit of power with the heavier oil also, not much tho I’m sure.
Old Sep 1, 2022 | 08:03 PM
sallen619's Avatar
sallen619
My oil runs 9-10 degrees hotter with 0W-40 as opposed to 5W-30.
Old Sep 1, 2022 | 08:19 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
The point being we are not talking about a "stock" cam and the advice being given does not appear to consider what the car actually needs.
"As for the proper oil to use with a hydraulic roller lifter, the best thing to do is consult with the supplier. However, we can say this, from our experience we've found that noisy hydraulic roller lifters result from using oil of the wrong viscosity. Oil that is too heavy will not fill the lifters as it should, too thin and the lifters will bleed down—in both cases the result is noisy lifters."
https://www.motortrend.com/news/dont-rub-cam-wrong-way/
To Oil temp range and 10w-40
