Engine oil cooler recommendations
I thought I could do more and I'm just now in the process of laying it down horizontally instead, to allow air to exit underneath and expose more of the rad.
I intend to test it out later this month at Mosport. While temps will be much cooler than a month ago at WGI, I do have data from previously in similar ambient, so I should be able to have a reasonable comparison...all things being equal.
I was going to make a separate post about this after I've completed and tested my little project (and may still do so), but here are some pics of my work in progress.
I still need to cut out my APR splitter's undertray which would normally cover the exit, as well as install a small wicker ahead of the opening.
Hopefully I'll get around to that later today. TBD
laid down horizontally
underneath view
protective grill
I’ve just cut the opening in my APR splitter’s small undertray, but won’t attach the small 1” wicker now.
i’ll prepare it to be easily bolted on with speed-clips at the track however, and test back to back if possible.
Hopefully conditions will be consistent enough to monitor any temperature differential as well as any dynamic difference (hope my *** is sensitive enough)
thanks again for this insight!!
So definitely try it with that second air dam in front of the cooler first. I would still be curious to know what difference it makes without it though, or with the front one and without the one under the radiator, etc. Keep us posted!
It was actually @Mordeth who explained this to me last year...but i wanted to try the cooler at 45 degrees first.
the dam behind it would try to push air through it (up into the engine compartment).
I think you need to move the large dam in front of the cooler to create that large low pressure area behind it that would pull air through the cooler from the engine compartment.
I’d be curious to see what yarn tufts do if you could get some GoPro video while you drive.
It is under the air intake tunnelling behind the grill.
This is ahead of the radiator separated from the engine bay along with radiator shrouding...which BTW, is fully sealed now to keep air from escaping the intake tunnel.
The flap may not even be necessary as this is a high pressure area funneling incoming cooling air directly to the radiator.
I was actually thinking that 'too much' air destined for the rad, may actually be escaping via my new opening this way (although it would have to turn 90 degrees down).
But compared to when the cooler was previously almost altogether blocking airflow to the actual rad, I don't think this is an issue. And its to this path of airflow that my wicker presumably adds negative pressure to draw it out underneath
Its the large OE airdam that pulls through the rad and engine bay (separated from the area ahead of it.
These are two separated low pressure areas. One before the rad (under oil cooler), one under the rad and rad shrouding.
Removing the airdam under the rad would be a problem, as we need its low pressure to evacuate air having passed through the radiator into the engine bay.
Mordeth had tested this and came to this conclusion....with very successful results.
Unfortunately its not really feasible to mount a go-pro and tufts anywhere underneath with approx 3" ground clearance at 150mph.
Moreover, the forecast for my test day on Thursday is cold, maybe 60f. So I surely won't have heat management issues. Nonetheless, i hope to be able to discern a trend, as I've run in these conditions before.
I went on a 200mile roadtrip last week (75mph) for a bit of a normal cruise, with one or two, quick 2nd gear pulls ....just to test a few other things out.
But ambient was a cool 65f and I couldn't get the water nor oil above 195~200f. In both cases it was obviously their respective thermostats just maintaining the minimum temperatures.
This doesn't tell me much, but it does seems I haven't messed anything up.
An additional thought worth mentioning is that if I were to do my project all over again, I would have tried mounting the OEM cooler this same way, horizontally with the IR thermostat kit and hoses/adapters. Instead, I ordered the larger cooler afterwards...and may have added to the cooling problem
Hope all this makes some sense
I don't think you want to try and "pushes air up through the cooler and out the radiator". You'd be trying to reverse the flow of air blasting in directly through the grill.
Moreover, the object is not to push the same air that has heated after going through the oil cooler into the rad,
If I wanted to do that, I'd figure a scoop over the entire oil cooler opening...but that would be loading the radiator with heated air. again.
I think...
I think...
It's just really hard to say with aero, there can be a lot of things happening you are not aware of.
But I'm not sure that it doesn't help evacuate engine bay heat. It must contribute to low pressure under the car. Perhaps an aero stability thing...if not cooling.
I keep falling back on the fact that this worked for Mordeth and he'd tested it extensively.
If anything, I'm bringing another smaller 1/2" wicker to put ahead of the oil cooler. The current one is 1". These should be easy to swap quickly, just drive the front onto the trailer ramps and 5 quick fasteners
And you're right, Mordeth tested this and the air dam worked well for him, but I am unclear on what he did exactly. I think he may actually have moved the large air dam in front of the oil cooler?
https://www.corvetteforum.com/forums...r-mods-16.html
plus to remove that one, I’d have to pull the splitter off again.
Ill try it like this for now first.
Forecast is only 57f.
In similar temps previously, water went to 225f, but oil still went to 235f…so I kinda have a comparison to gauge by.
thanks for your thoughts.
