Help on buttoning up my engine?
Old Sep 20, 2022 | 11:30 PM
JayTheHobo's Avatar
JayTheHobo
Default Help on buttoning up my engine?
Hi there im buttoning up my swap and would love some help... i didnt take enough pictures i guess and forgot where a few things went. The 2 brackets are off the intake just not sure where exactly. The silver c looking bracket im not sure as i wasnt the one that took that off. The ground strap i believe goes to the fuel rail.... again just not sure where. Any help would be much appreciated.
2005 ls2 auto. Engine pulled due to damaged crank.
Old Sep 21, 2022 | 12:35 AM
JayTheHobo's Avatar
JayTheHobo
here. I found a pic of the brackets and how theyre mounted. Just need help finding the location of that weird ground strap.
Old Sep 21, 2022 | 07:53 PM
JayTheHobo's Avatar
JayTheHobo
The c looking piece goes to the power steering pump.
Old Sep 21, 2022 | 07:56 PM
JayTheHobo's Avatar
JayTheHobo
here is a closeup view of the last piece. It appears to be a ground? Somewhere around the intake or fuel rail area im pretty sure?
Old Sep 22, 2022 | 11:17 AM
rockymountain1999's Avatar
rockymountain1999
2021 C6 of the Year Finalist - Modified
I did a cam and clutch swap on an Ls1 several years ago. This strap looks like the one that was holding back/supporting the stiff wire bundle that runs down past the bell housing and into the torque tube and back to the transmission. Maybe this is what that is?
Old Sep 22, 2022 | 05:45 PM
JayTheHobo's Avatar
JayTheHobo
Ill get down there and see it it matches up with the holes and get back with you. Thanks a bunch
To Help on buttoning up my engine?
