Only 400whp cam,headers ls2???
Old Oct 1, 2022 | 07:54 PM
C6ROB3151's Avatar
C6ROB3151
5th Gear
Default Only 400whp cam,headers ls2???
hello all i recently got my ls2 c6 dyno tuned and only made 400whp with a stage 3 turbo cam,cai,and long tube headers no cats full straight pipe. the car is NA will be doing a single turbo kit soon, Is that right??? thought it would make more. the cam specs are 230/235 .615"/.614" 114LSA
thanks in advance
car was tuned on a hub dyno
and is a manual
the car was completely stock before, est 344whp
Old Oct 1, 2022 | 08:25 PM
Omega Doom's Avatar
Omega Doom
well depending on the dyno and temperature and mainly tuner yes that seems very low but also is this an M6 or A6 either way its very low
Old Oct 1, 2022 | 08:27 PM
C6ROB3151's Avatar
C6ROB3151
5th Gear
its a m6
Old Oct 1, 2022 | 08:48 PM
CTD's Avatar
CTD
If you do not have a previous dyno report prior to modifications on the same dyno your question is meaningless to most of us.
Old Oct 1, 2022 | 08:58 PM
C6ROB3151's Avatar
C6ROB3151
5th Gear
sorry the car was stock before est 344 whp
Old Oct 1, 2022 | 09:45 PM
Omega Doom's Avatar
Omega Doom
well maybe its the stock sorry *** LS2 intake holding power back? either swap a set of LS3 heads and intake or at least buy a Fast 92 or 102 intake and NW or Katech TB
Old Oct 3, 2022 | 01:09 PM
72greg's Avatar
72greg
With LT headers, MSD atomic intake, Nick Williams TB and a tune I gained right at 50HP to put my 90k mile LS2 at 400RWHP. Since I track the car, I'm not going after any more ponies at this point. I'd like to get to 500HP to run with the Z's but I have some driving improvement to do before I go after the internals and add yet MORE cooling.
Old Oct 4, 2022 | 09:30 AM
Spaceme1117's Avatar
Spaceme1117
I used to have a 2006 GTO. It has the LS2 and a 4-speed auto. I installed a cam with similar specs as yours and long tube headers. Put down exactly 400hp on a Dynojet.
Your car should be reading a little bit higher but not a huge amount more. But different dynos read differently. The main thing is how the car feels and drives. A much better test of gains, would be before and after of quarter mile times and speeds.
Your car going from 344 to 400, a gain of 56 is actually quite good.
Old Oct 4, 2022 | 01:52 PM
5knives's Avatar
5knives
I'm not smart enough to know anything by the cam specs but I'd say those power numbers are accurate. I believe when my build had similar mods as you, I put down 409rwhp on a Dynojet roller. As long as your cam is set up for your turbo application, and you have a competent tuner, I wouldn't worry about it.
To Only 400whp cam,headers ls2???
