Improve Throttle Response and Acceleration
PedalMAX is easy to install and provides a HUGE improvement in throttle performance.
It plugs in-line between the vehicle's pedal position sensor and vehicle harness. A control **** is included to adjust your performance "on-the-fly".
PedalMAX is fully water-proof and utilizes OEM quality connectors.
https://www.xplosiveperformance.com/jmspedalmax.html
Faster Downshifts W/Auto Trans
Reduce Throttle Hang On Manual Trans
Simple to Install & Waterproof
Eliminate Turbo Lag
Boost Low to Mid-Range Performance
Factory & Aftermarket Tuning Compatible
Supports Most Vehicles
Adjustment Dial Included
Designed & Assembled in the USA
Designed and produced in the USA by a performance company that has been in the industry since 1993
We are proud that PedalMAX® has been issued multiple ARB EO's
https://www.xplosiveperformance.com/...-px1015gm.html
Good luck on this, I hope anyone with a 2005 checks out the return policy before ordering. If someone does come out with a 2005 C6 TC they will have a lot of happy customers.
The APP inputs to the ECU have pullup resistors on them.
There is a correlation check that fails anytime because of the current required to overcome the pullup voltage level you get the following DTC
P060D Control Module Accelerator Pedal Position (APP) System Performance ECM
So sorry it will not work on 2005 they have adjusted the working models
ELIMINATE THROTTLE DELAY
Improve your vehicles’ throttle response and driving
characteristics with PedalMAX®. Throttle response and
acceleration are improved, boosted applications see a big lag
reduction, all leading to better initial power and torque.
