Need help with my nightmare
Old Oct 8, 2022 | 02:46 PM
old motorhead's Avatar
old motorhead
Originally Posted by russ472
technically it can run without o2 sensors. speed density open loop tune. although I highly doubt the OP would have a tune set up like that.
Ahhhhh shoot. You got me on that one...
Old Oct 8, 2022 | 07:30 PM
freaknbigpanda's Avatar
freaknbigpanda
Really sounds like a bad tune, I would flash it back to stock at a dealer and see if your problems go away. Put the stock exhaust back if you need to.
Old Oct 15, 2022 | 10:11 PM
C6VetteLover's Avatar
C6VetteLover
Any updates? Did they fix the tune?
Old Oct 18, 2022 | 12:02 PM
C6Vader's Avatar
C6Vader
Cruising
Hello everyone, so after trying the "parts cannon" I ended up having my car towed to an LS performance shop. The issues were pretty simple, it was just a blown o2 sensor fuse and as expected the timing of my original tune was all over the place. Car was fixed and properly dynod. Runs like normal but now I'm having a wheel spacing issue, the woes of life.
Old Oct 18, 2022 | 12:43 PM
C6Vader's Avatar
C6Vader
Cruising
Originally Posted by buckmeister2
It is possible the problem was caused with the initial tune, which created problems to continue to crop up, all due to the original tune.
Hope the re-set to factory helps, though you should expect possible air/fuel ratio issues, and maybe 02 issues, both of which can be corrected with a tuner who really knows what he/she is doing. Let us know how it comes out.
This is pretty much exactly what is was. One bad underlying issue caused a spew of other issues to occur. Went to a shop called LSxcellence and they got me all sorted out.
Old Oct 19, 2022 | 07:29 PM
Corvette_Dez's Avatar
Corvette_Dez
Must have been a pretty healthy tow bill going all the way to P-Park!
Old Oct 20, 2022 | 12:32 PM
C6Vader's Avatar
C6Vader
Cruising
Yeah right XD, was trying to use triple a for almost a week to get it done but they had tow limit restrictions because of the hurricane. 300$ total :/
Old Oct 21, 2022 | 02:22 AM
Corvette_Dez
Damn, that sucks. BTW I live around the corner from you. Lol
